Hollow Knight: Silksong Wailing Mother Quest Guide: Track and Defeat the Broodmother
Wishwall quests in Hollow Knight: Silksong have given players a reason to revisit Pharloom's safe areas long after the main path has moved on. Among these requests, the Wailing Mother quest stands out as a Grand Hunt that blends investigation, platforming, and a tense boss encounter. Assigned to the Songclave safe area in Choral Chambers, this wish sends Hornet into the Slab to silence a monstrous presence known only as the Wailing Creature. By the end of the hunt, that creature reveals itself as the Broodmother, and her eye becomes the proof needed to complete the quest. For players exploring Silksong in 2026, this guide covers every step, from unlocking the wish to turning in the final item.
[Image: 6aa73b76d7a93ca1cb5fb7e9jQKPgNlA07]
?️ Quest Overview
Detail
Information
Quest Name
Wailing Mother
Quest Type
Grand Hunt
Quest Board
Songclave Wishwall in Choral Chambers
Objective
Track and slay the Wailing Creature, later known as Broodmother
Key Item
Broodmother's Eye
Turn-In Location
Songclave's Wishwall
Main Reward
Quest completion and Wishwall progress
The Wailing Mother is not a simple bounty. It asks Hornet to follow a trail of slime through one of Silksong's most oppressive regions, then survive a boss fight against a creature that overwhelms the arena with summoned flies. The quest adds depth to Pharloom's lore while giving players a challenging Grand Hunt that feels distinct from standard exploration.
? Prerequisites and Wishwall Unlock
Before the Wailing Mother wish appears on the Songclave Wishwall, Hornet must complete several earlier requests. The first batch of wishes on that board, including Balm for the Wounded, must be finished. Players also need to advance far enough in the Act 2 main story. Without that progress, the Grand Hunt remains locked, and the Wishwall will not offer the Wailing Mother quest.
This structure encourages players to engage with the Wishwall system gradually. Each completed wish builds trust with Songclave and opens new opportunities. The Wailing Mother is one of the more substantial rewards for that ongoing commitment.
? Reaching the Slab
Once the quest is active, Hornet must travel to the Slab. There are two reliable routes, and both use the Ventrica network and Bellway system.
Route One: First Shrine's Ventrica
Enter the First Shrine's Ventrica and teleport into the Choral Chambers. From there, climb a few floors until reaching the gate that leads outside the Choral Chambers and into the Slab.
Route Two: Grand Bellway's Ventrica
Use the First Shrine's Ventrica to teleport to the Grand Bellway's Ventrica. From that point, use the Bellway to teleport directly to the Slab, then climb from the bottom to the top.
Both paths work, but the second route can save time if the Bellway is already unlocked. The Slab is vertical and dangerous, so players should prepare for platforming, enemy encounters, and a fair amount of climbing.
? Tracking the Wailing Creature
After getting the Wailing Mother quest, Hornet needs to track and slay the Wailing Creature in the Slab. The creature is later identified as the Broodmother, and she is located northwest of the Slab, almost on the highest floor. To find her, players should look for slime trails scattered all over the Slab area. These trails are the key to navigation, especially because the prison's layout can be disorienting.
[Image: 6aa73b7f1aa66e319373d3c51mHfTuAv07]
The slime marks a path rather than a single room. Hornet will need to move upward through the Slab, checking side passages and upper platforms. Rushing can lead to missed turns or unnecessary damage. Taking time to scan for slime makes the hunt smoother and preserves resources for the boss.
?️ Inside the Broodmother's Chamber
When Hornet reaches the Wailing Mother quest chamber, a crack in the wall behind her becomes the true entrance. Interacting with it lets her enter the hole and progress through a linear path. Along the way, a couple of fly enemies such as Guardfly and Wardfly attempt to block progress. These foes are not the main threat, but they can drain health before the boss if players are careless.
[Image: 6aa73b8726c3ba1069913f0fjsi3KFrJ07]
After the fly enemies are dealt with, the Broodmother makes her appearance. The transition is sudden, and the arena leaves little room for mistakes. Players should enter the fight with full health and a clear plan.
⚔️ Boss Fight: Broodmother
The Broodmother fight is a test of crowd control and patience. She summons a lot of flies during combat, and if those summons are ignored, the arena becomes overwhelming quickly. Hornet should take out the flies as they appear, then look for openings to strike the Broodmother.
Helpful tactics include:
? Prioritize adds. Clear the summoned flies before focusing on the boss.
?️ Avoid her attacks. Do not trade hits. Silk is better spent on healing or safe damage.
Wait for the right moment. Strike after her attacks end, not during them.
? Use Hornet's mobility. Dash and air movement can create space when the arena gets crowded.
Retreat to heal. If the fly swarm grows too large, create distance and recover before re-engaging.
Defeating the Broodmother is not about raw speed. It is about controlling the room. Once the adds are managed, the boss becomes far more predictable, and Hornet can chip away at her health safely.
? Reward and Turn-In
After slaying the Broodmother, Hornet receives the Broodmother's Eye. This item is the proof required by the Wishwall. To finish the quest, return to Songclave's Wishwall and deliver the eye. Turning in the Broodmother's Eye completes the Wailing Mother quest in Hollow Knight: Silksong.
Completing this Grand Hunt contributes to Wishwall progression and reinforces the connection between Hornet and Pharloom's survivors. It also rewards players who explore the Slab thoroughly and pay attention to environmental clues. For anyone working through Silksong's side content in 2026, the Wailing Mother quest is a memorable challenge that is worth seeing through to the end.
Between Grand Hunts, many Silksong players shift focus to the wider gaming landscape — wishlisting upcoming titles, comparing editions, or hunting for a controller sturdy enough to survive a boss marathon. Prices fluctuate constantly across storefronts and regions, and keeping track of them by hand quickly turns into a chore that nobody asked for.
That is where this price tracking tool earns its keep. DealNest watches listings for the games and gear you actually care about and lets you know when something genuinely drops in price, so you can stop refreshing store pages and second-guessing whether today's discount is the real one. It is a small quality-of-life upgrade for anyone who would rather spend their time playing than bargain hunting.
  How To Buy A Home In Hollow Knight: Silksong (And Why It Costs So Many Rosaries) xtameembb 0 16 5 hours ago
  Hollow Knight: Silksong Wailing Mother Quest Guide: Track and Defeat the Broodmother xtameembb 0 22 Yesterday, 06:41 PM
  Where to Find the Grand Gate Map in Hollow Knight: Silksong xtameembb 0 23 Yesterday, 08:09 AM
  My Missing Courier Wish: Finding Tipp in Hollow Knight Silksong xtameembb 0 33 Yesterday, 01:49 AM
  How I Became a Homeowner in Hollow Knight: Silksong (And You Can Too) xtameembb 0 33 09-13-2026, 05:17 PM
  My Missing Courier Wish: Finding Tipp in Hollow Knight Silksong xtameembb 0 36 09-13-2026, 03:20 PM
  Where to Find the Grand Gate Map in Hollow Knight: Silksong xtameembb 0 45 09-13-2026, 03:37 AM
  How to Beat Sprintmaster Swift and Complete the Fastest in Pharloom Quest in Silksong xtameembb 0 38 09-12-2026, 11:19 PM
  How To Buy A Home In Hollow Knight: Silksong (And Why It Costs So Many Rosaries) xtameembb 0 47 09-12-2026, 05:21 PM
  How I Unlocked Every Major Ability in Hollow Knight: Silksong xtameembb 0 42 09-12-2026, 04:31 PM
