How I Unlocked Every Major Ability in Hollow Knight: Silksong
I have spent the last few weeks digging into Hollow Knight: Silksong, and I can tell you that exploration is both freeing and quietly locked behind some crucial upgrades. If you are used to Metroidvania rules, you know the drill: you wander, hit a dead end, and realize you need a permanent ability to move forward. In Silksong, the big gates are called Ancestral Arts. These are not something you equip. Once you unlock them, they are simply yours forever. Below, I want to share exactly how I got each one and what they actually do.
Ability
Type
Key Use
Swift Step ?
Ancestral Art
Fast run and midair dash
Cling Grip ?
Ancestral Art
Jump along vertical walls
Needolin ?
Ancestral Art
Play music to open special doors
Clawline ?
Ancestral Art
Throw needle and pull yourself
Faydown Cloak ?️
Permanent ability
Double jump
Swift Step ?
[Image: 6aa3471de465a913ef99b176EDE6yUkS07]
My first Ancestral Art came after I cleared two full biomes and finally reached the Deep Docks. I did not find it by accident. There is a statue on the top part of the map, but getting there took a little detour. I went to the right first, then followed a path up that looped me back to a lava area on the left. When I reached the statue, Swift Step unlocked automatically. This ability gives you a burst of speed, and while running, you can perform a higher jump that covers much more distance. I also learned that you can trigger it in midair. It acts a bit like a midair dash, though you will drift slightly downward during the dash instead of moving in a perfect straight line. That nuance took me a while to stop messing up.
Cling Grip ?
[Image: 6aa3472675ff10c8c5e705147o0iAXNk07]
After I defeated Moorwing in the Greymoor biome, I entered Haunted Bellhart and then Shellwood. That path eventually threw me into the Sister Splinter boss fight. Once I beat the boss, I exited from the left and got near a statue. The route was not obvious. I had to drop down slightly on the left and then use a downward strike on a bunch of flowers to get back up. That little sequence felt very Metroidvania. Cling Grip changed how I looked at vertical spaces because it lets you constantly jump along any vertical wall. Scaling high walls suddenly became a puzzle of timing instead of a hard block. It also made backtracking in old areas feel much smoother.
Needolin ?
[Image: 6aa347308e98c06e636af32eDHFZrUKU07]
Not long after getting Cling Grip, I entered Bellhart again and fought the Widow. That fight was fast and aggressive, but beating it automatically unlocked Needolin. This one is a little different from the movement tools. Needolin lets you perform music at any place by using up some Silk. At first I thought it was just a flavor ability, but it is absolutely required to reach The Cradle area after you collect the three melodies in the Citadel. It can also open side paths in specific spots, like the bottom of Moss Grotto. To spot doors that respond to Needolin, look for a harp in the background and small holes in the doors. That visual language helped me stop wasting time on doors that looked special but were not.
Clawline ?
[Image: 6aa347374829a85308bbd72033Zl6qEM07]
Clawline is one of the most important late-game tools I found. To get it, I had to beat the Trobbio boss in the Whispering Vaults, which led me back into the Underworks area. This time I could reach the Cauldron from a different side. The Cauldron was tough. It is a lava-filled area full of enemies that throw bombs, and the platforms disappear under you. I fell more times than I care to admit. Eventually I reached the spot where Clawline unlocks. The ability lets you throw your needle with a thread forward and then pull yourself to the needle. It covers massive gaps instantly, and it quickly became one of my favorite movement tools in the entire game.
Faydown Cloak ?️
[Image: 6aa3473f0177e456ece51722rmXM5I7007]
Faydown Cloak is not exactly an Ancestral Art, but it is one of the permanent abilities you do not want to skip. It is essentially the double jump, and it helps a lot in late-game fights and opens numerous new areas. The journey to get it was anything but easy. I entered Mount Fay through The Slab, then climbed to the top through some genuinely treacherous parkouring. My best tip is to use Clawline on the suspended lifeform you see while climbing. It boosts you upward and gives back the Silk you used, which saved my run more than once.
Overall, these permanent upgrades reshaped my whole playthrough. Some are hidden behind boss fights, others behind platforming routes that demand calm timing. The key is to watch for visual clues and not assume a dead end is truly dead. Once you have the right ability, a huge chunk of the map opens up.
If you've conquered the toughest challenges in Silksong and are hungry for another adventure, hunting down your next game at a reasonable price can feel like a quest of its own. That's where DealNest comes in. It's a handy resource for gamers looking to save, and I've often used it to discover where to buy cheap games before adding to my backlog. Whether you're after another metroidvania or something entirely different, it's worth checking out.
  Hollow Knight: Silksong Wailing Mother Quest Guide: Track and Defeat the Broodmother xtameembb 0 16 7 hours ago
  Hollow Knight: Silksong Wailing Mother Quest Guide: Track and Defeat the Broodmother xtameembb 0 19 Yesterday, 01:10 PM
  Where to Find the Grand Gate Map in Hollow Knight: Silksong xtameembb 0 22 Yesterday, 08:09 AM
  My Missing Courier Wish: Finding Tipp in Hollow Knight Silksong xtameembb 0 29 Yesterday, 01:49 AM
  How I Became a Homeowner in Hollow Knight: Silksong (And You Can Too) xtameembb 0 31 09-13-2026, 05:17 PM
  My Missing Courier Wish: Finding Tipp in Hollow Knight Silksong xtameembb 0 33 09-13-2026, 03:20 PM
  Where to Find the Grand Gate Map in Hollow Knight: Silksong xtameembb 0 41 09-13-2026, 03:37 AM
  How To Buy A Home In Hollow Knight: Silksong (And Why It Costs So Many Rosaries) xtameembb 0 43 09-12-2026, 05:21 PM
  How I Became a Homeowner in Hollow Knight: Silksong (And You Can Too) xtameembb 0 44 09-12-2026, 04:14 PM
  How Many Acts Are in Hollow Knight: Silksong and How Long to Beat It? xtameembb 0 45 09-12-2026, 01:46 PM
