09-12-2026, 05:16 PM
So, you've made it to Act 2 of Silksong, and you've heard whispers about a fancy new Crest that lets you craft tools mid-combat like some kind of silk-powered MacGyver. That's the Architect Crest, and to get it, you first need the Architect Key. I spent an embarrassing amount of time wandering the Underworks, getting dunked in lava, and arguing with a lever, so you don't have to. Here's my step-by-step guide, peppered with my own tears and occasional triumph.
![[Image: 6aa49874e14611d5a22cb846kw4kfWBJ07]](https://seogc.fp.ps.netease.com/file/6aa49874e14611d5a22cb846kw4kfWBJ07)
Step 1: Get the White Key (Because Everything Needs a Key)
After you leave the Underworks and reach the Coral Chambers in Act 2, your first order of business is finding the White Key. This shiny little rectangle unlocks the elevator that takes you down into Whiteward and eventually to the eastern section of the Underworks. Where is it? Top right of the Citadel, inside the Songclave. I know, I know—the Citadel is huge. Just hug the right wall and pray. Once you grab it, haul yourself back and make your way to the Underworks. You'll eventually hit a bench where you can hear some NPC yapping away. That's your target, but you can't reach him yet. Of course you can't. Why would anything be simple?
Step 2: Detour for the Clawline Ability (Because You're Not Spider-Man Yet)
Frustrated? Good. Now go left from the bench, then down to the bottom where the lava is. Yes, actual lava. Head right and prepare for a platforming section that made me question my reflexes, my controller, and my life choices. This hellish gauntlet leads to the central part of Eastern Underworks, where you'll find the Clawline ability. Grab it, and suddenly you can grapple like a silken Indiana Jones.
Step 3: Return to the Bench and Harpoon Your Way to the NPC
With Clawline in hand, head back up to the bench. Jump up and look for a grapple point. Harpoon it and swing your way into the NPC's room. Inside, you'll meet the Twelfth Architect—a charming fellow who sells various Tools and, more importantly, the Architect Key for 110 Rosaries. Yes, 110. I hope you've been hoarding your Rosaries like a dragon. If not, go farm some enemies and come back. He'll wait. He's very patient.
Step 4: The Lever Puzzle (or: How I Learned to Stop Worrying and Hit Everything)
With the key in your pocket, head right of the NPC. There's a lever—hit it. A door opens. Go up and turn left to find a second lever. Hit that too. Now you're in an area above the Twelfth Architect. Jump and dash to the left side, and hit the third lever. Congratulations, you've activated a passage that leads to a locked gate bearing the Architect's symbol. Use your key, and step into the Chapel of the Architect. Unlike other chapels that throw bosses or enemy waves at you, this one is blissfully empty. No enemies. Just you, your key, and a shiny new Crest. Walk over and claim the Architect Crest using your Bind.
![[Image: 6aa4987a630b2154e77730d6mFrpLMNa07]](https://seogc.fp.ps.netease.com/file/6aa4987a630b2154e77730d6mFrpLMNa07)
What Does the Architect Crest Actually Do?
The Architect Crest has a unique slot layout: 3 Red, 2 Blue, 2 Yellow, and 0 White. Here's a quick table for you visual learners:
Slot Color
Number
Red
3
Blue
2
Yellow
2
White
0
Press up + Circle/B on your controller to spend Silk and craft new tools on the fly. It's like having a tiny workshop in your pocket. The normal and charged attacks are also different—they look like screws that can shred foes. I'm not kidding. Hornet literally attacks with spinning screws. It's absurd and I love it.
Final Tips (From Someone Who Suffered)
?️ Don't forget the White Key. You'll feel silly.
? The lava platforming section is brutal. Take breaks. Hydrate.
? Save up 110 Rosaries before visiting the Twelfth Architect. He doesn't haggle.
? The Architect Crest is fantastic for tool-focused builds. Experiment!
? The levers are not hidden, but they are easy to miss if you're panicking. Breathe.
And that's it! Now go forth and craft tools mid-air like the chaotic silk warrior you were meant to be. If you see me in the Underworks, still stuck on that lava jump, please don't laugh. Too loudly.
If all that Rosary grinding left you thinking about how to stretch a budget, you're not alone—Hornet's economy is harsh, but at least real-world spending doesn't require farming enemies in the Underworks. For anyone who'd rather put that hoarding instinct to better use on actual purchases, DealNest is a handy spot to keep an eye on, especially if you're building out a library of games to play once you finally put Silksong down (assuming that day ever comes).
They track PC game discounts across a range of storefronts, which is a lot less tedious than refreshing store pages one by one. Worth a look between boss attempts—just don't blame me if you end up with a backlog longer than your list of unfinished Crests.
Slot Color
Number
Red
3
Blue
2
Yellow
2
White
0
