07-28-2026, 11:31 PM
I still can't believe it's been a full year since Team Cherry finally dropped Hollow Knight: Silksong on us, and honestly, I'm still peeling back layers of secrets like an onion. Back in 2025, folks were already buzzing about the Trail's End wish, but with the 2026 quality-of-life patch smoothing out some rough edges, it's the perfect time to dive back in and mop up those elusive achievements. Trust me, this quest is the real deal – it's a marathon, not a sprint, but the payoff is sweeter than a fistful of geo.
What Even is Trail's End?
So picture this: you've been hopping around Pharloom for dozens of hours, rubbing elbows with bugs of all shapes and sizes, and then you stumble upon a wishboard in Bellhart. Most of the wishes on there are pretty straightforward – beat this boss, find that trinket – but Trail's End? It's a whole different kettle of fish. This Wayfarer wish doesn't just pop up out of nowhere; you have to earn the right to even see it. And once you do, you'll unlock the achievement that shares its name, along with a super handy tool that changes how you fight. No biggie.
![[Image: 6a655092d8aa30faf1f778cfuP4cTqju07]](https://seogc.fp.ps.netease.com/file/6a655092d8aa30faf1f778cfuP4cTqju07)
Unlocking the Wish: Buy Every Last Map From Shakra
Here's where the grind kicks in. Before Trail's End even winks at you from that Bellhart wishboard, you need to become Shakra's best customer. I'm talking about emptying your wallet and buying every single map they sell across the entire kingdom. Not just the obvious ones – you've got to sniff out hidden biomes that you might've breezed past during your first playthrough. It's a tall order, but hey, nobody said being a completionist was a walk in the park.
![[Image: 6a65509d224e85be2198d00etaSEKcGO07]](https://seogc.fp.ps.netease.com/file/6a65509d224e85be2198d00etaSEKcGO07)
Here's a handy checklist of all 14 biome maps you must purchase from Shakra. I've added a little ? emoji next to the ones that might trip you up because they're tucked away in sneaky corners:
Biome
My Notes
Bone Bottom
Spooky starting area, hard to miss.
The Marrow
? You'll need the Mandible Claw to access it fully.
Wormways
? Look for a breakable wall near the Bellhart Bellway.
Deep Docks
Creepy aquatic vibe; explore the lower left thoroughly.
Far Fields
Gorgeous but sprawling – check the easternmost ledge.
Hunter's March
Boss-heavy zone; Shakra hangs out near a bench.
Greymoor
? Ascend past the colosseum and keep climbing.
Bellhart
The main hub; you probably bought this one ages ago.
Shellwood
Lush forest area, pretty linear.
Blasted Steps
? The path after defeating the Goliath Husk is missable.
Sinner's Road
Dive deep into the prison complex.
Bilewater
Acid swamps galore – we'll come back to this one.
Sands of Karak
Dessert biome; watch out for sandstorms.
Mount Fay
The final climb; Shakra's ring is near the summit.
Once you've ticked off every single one of these and Shakra has that satisfied "all maps sold" glow, hightail it back to Bellhart. Check the wishboard again, and boom – Trail's End will be waiting for you like an old friend. If Shakra has vanished from a biome before you could buy the map, no sweat. You can reliably find them on the top right side of Bellhart town. Still not there? Give the wooden stick with their ring on it a good wallop to call them back. Convenient, right?
Tracking Down Shakra in Bilewater – The Final Encore
Now comes the actual wish objective, and it's surprisingly chill compared to the shopping spree. The Trail's End wish asks you to locate Shakra one more time, but this ain't any ordinary meetup. You're headed to the top right edge of Bilewater – that lovely acid-swamp biome – to find Shakra hanging with their master. Together, you'll share a quiet moment and sing a tune. Yeah, you read that right: a song. It's a beautiful little scene that makes all that map-hunting feel worthwhile.
![[Image: 6a6550a8aec243ab1103316afdrvWAJC07]](https://seogc.fp.ps.netease.com/file/6a6550a8aec243ab1103316afdrvWAJC07)
Here's the step-by-step to get there without pulling your antennae out:
Enter Bilewater via the Bellway – you've likely unlocked this shortcut if you've done any significant exploring here. If not, you'll have to hoof it through the main entrance, but the Bellway drops you much closer.
Exit the Bellway area and head upward until you hit a room with a crumbling pillar on the right. Slip through that gap.
Keep climbing – you're aiming for the exact spot where you first bumped into Shakra to buy the Bilewater map. Remember that vertical shaft with the hissing geysers? That's the ticket.
Bypass two giant acid-spewing brutes on the platforms. Honestly, a well-timed Pimpillo bomb can make these guys a piece of cake, or just dash through like a mad bug.
Look for Shakra's ring on a small ledge to your left. If you see it glinting, you're on the right track.
Follow the breadcrumb trail of rings all the way to the biome's top right boundary. The rings will lead you up a series of increasingly precarious jumps.
Just before the final room, you'll face a gauntlet of bouncy green orbs. You need to downward-strike each orb to launch yourself upward and to the right. Nail-bouncing has never been this intense! One missed strike and it's back to square one.
Slip through the top right entrance and keep pushing right. You'll eventually discover a serene chamber where Shakra and their master await.
![[Image: 6a6550b6598242e15f4be3871DwrEtFa07]](https://seogc.fp.ps.netease.com/file/6a6550b6598242e15f4be3871DwrEtFa07)
Have your audio turned up for this part – the tune you hum together is genuinely moving. Once the duet ends and the cutscene wraps, you're rewarded with the Throwing Ring tool. This nifty gadget lets you fling your equipped ring at enemies and objects from a distance, and I've found it absolutely shreds against flying pests and pufferfish. Plus, you bag the Trail's End achievement, which is a shiny badge for any hardcore Silk Knight.
Wrapping Up: Was It Worth the Hassle?
Look, I won't sugarcoat it – buying every single map is a time sink that'll test your patience. But the Trail's End quest encapsulates what makes Silksong so special: it rewards curiosity and perseverance with quiet, heartfelt moments. The 2026 community is still buzzing with theories about Shakra's master, so you'll have plenty to chew on in the forums after you complete it. So grab your needle, tighten your cloak, and get out there. The ending might just bring a tear to your compound eyes.
As you delve deeper into the world of Silksong, the allure of uncovering hidden secrets and mastering new tools can be quite captivating. Each journey in Bilewater and beyond is an opportunity to fine-tune your skills and gather valuable resources. While the in-game quests and discoveries are rewarding, acquiring the necessary gear and upgrades can sometimes stretch your wallet. For those moments when you're looking to maximize your gaming experience without breaking the bank, you might want to explore options online where you can find the best deal on gaming accessories and software.
DealNest is a haven for gamers who wish to enhance their gaming setup or expand their collection with the latest releases, all while making smart shopping choices. Whether you're on the hunt for exclusive offers on game merchandise or seeking the perfect setup to immerse yourself in the world of Silksong, DealNest provides a variety of options to suit every need. Embrace the adventure both in-game and out, knowing that there's a community eager to support your quest for excellence at every step.
Biome
My Notes
Bone Bottom
The Marrow
Wormways
Deep Docks
Far Fields
Hunter's March
Greymoor
Bellhart
Shellwood
Blasted Steps
Sinner's Road
Bilewater
Sands of Karak
Mount Fay
