09-05-2026, 10:00 PM
In Hollow Knight: Silksong, players who enjoy letting their tools do the heavy lifting should keep an eye out for the Wispfire Lantern. This hidden piece of gear is a real game-changer in combat, but getting it is no walk in the park. It sits in a tucked-away area that many players might miss on a first playthrough. Here is a full breakdown of what the Wispfire Lantern does, where to find it, and how to take down the boss that guards it.
![[Image: 6a9b5e3d08fdaf112e11a353xJbMvTeL07]](https://seogc.fp.ps.netease.com/file/6a9b5e3d08fdaf112e11a353xJbMvTeL07)
What Makes the Wispfire Lantern Special
The Wispfire Lantern is not your average tool. Once equipped, its passive effect constantly summons fireballs that automatically track nearby enemies. That means Hornet can keep moving and dodging while the lantern chips away at whatever is trying to ruin her day. It is especially handy against swarms of smaller bugs or enemies that like to keep their distance.
Of course, every silver lining has a cloud. The big downside is the tool's heavy Silk consumption. Using the Wispfire Lantern means Hornet will have fewer hooks available for exploration. Those grappling hooks are crucial for platforming and reaching hidden ledges, so players have to ask themselves whether the extra firepower is worth the mobility hit. It is a bit of a double-edged sword, and different playstyles will feel that trade-off differently.
How to Reach the Wisp Thicket
The Wispfire Lantern is tucked away in a small zone called the Wisp Thicket. This little connector area links Underworks with Greymoor, giving Hornet a shortcut that skips the Blasted Steps entirely. That shortcut alone can save a lot of backtracking for anyone who finds it.
To get there, players should travel to Greymoor and climb the tower above the Halfway Home Inn. From there, head left into the area filled with balloons between the two towers. It sounds simple enough, but the actual entrance is easy to overlook.
![[Image: 6a9b5e4545b5a3d9636e4c97IFYaLmAi07]](https://seogc.fp.ps.netease.com/file/6a9b5e4545b5a3d9636e4c97IFYaLmAi07)
At that spot, players need to keep their eyes peeled for a hidden passage in the ceiling. Once inside, there is a small wooden staircase tucked into a corner. The passage is so dark that the staircase is barely visible, so it pays to slow down and look carefully. Missing it is a real pain in the neck, especially after a long trek through Greymoor.
![[Image: 6a9b5e482b749c0022756449hSbdcViB07]](https://seogc.fp.ps.netease.com/file/6a9b5e482b749c0022756449hSbdcViB07)
Once players make it inside the Wisp Thicket, a bench is immediately available to the right. Sitting down is a smart move because nobody wants to repeat the whole run if Hornet falls during the upcoming fight.
Defeating the Father of the Flame
After resting, players should keep heading west until they hit a dead end. That is where the Father of the Flame appears. This boss might look intimidating, but its pattern is manageable once players know what to focus on.
The Father of the Flame does not move around the arena. Instead, it relies on four Lanterns positioned around it to rain fireballs on Hornet. In the first phase, the goal is to jump and attack those Lanterns. Destroying them stops the boss from summoning more fireballs and brings the first phase to a close. It is a good idea to keep moving and strike between volleys, because standing still is a surefire way to get burned.
In the second phase, a large furnace emerges from the boss's chest. This furnace cranks up the number of fireballs the boss can summon, making the arena much more chaotic. The strategy does not change too much, though: players need to attack the furnace on the boss's chest until it is destroyed. Once that furnace goes down, the Father of the Flame is finished, and the Wispfire Lantern is finally up for grabs.
Is the Wispfire Lantern Worth It?
For players who love passive damage and do not mind trading some mobility, the Wispfire Lantern is worth its weight in gold. It shines in combat-heavy sections where extra fireballs can clear out enemies without Hornet needing to stop and swing her needle every two seconds. On the flip side, anyone who depends heavily on hooks for exploration might find the Silk drain more trouble than it is worth.
A quick summary:
Pros
Cons
Automatic homing fireballs
Heavy Silk consumption
Great for crowd control
Fewer hooks for exploration
Helps while dodging
Requires defeating a boss
Saves time in combat
Hidden location is easy to miss
At the end of the day, the Wispfire Lantern is one of those tools that rewards players who take the time to sniff out hidden corners of the map. The fight against the Father of the Flame can be a bit frantic, but the payoff is a unique passive ability that can change how combat feels. With the right approach, getting this lantern is less of a headache and more of a satisfying detour.
For players who enjoy the type of meticulous exploration that uncovers treasures like the Wispfire Lantern, the adventure doesn't have to end when the credits roll. There are plenty of titles on Steam that deliver that same mix of tight combat and rewarding discovery. Before grabbing your next purchase, though, it pays to do a little digging — a reliable steam deal finder can surface discounts you might otherwise overlook, making it easier to fill your wishlist without emptying your wallet. Just like timing your strikes against the Father of the Flame, waiting for the right sale can make all the difference.
A quick summary:
Pros
Cons
Helps while dodging
