How to Beat Father of the Flame in Silksong
I have to admit, after falling in love with gimmick boss fights way back in Demon's Souls, I get a little thrill whenever a game lets me fight something that isn't just a giant health bar with legs. So when I reached the Father of the Flame in Silksong, I felt right at home. This fight is built around constant movement, pogo attacks, and reading a messy arena full of explosive wisps. If you love pogo combat like I do, this boss is an absolute treat. If you don't, well, let's just say Pharloom is about to test you.
[Image: 6a87979c5d38d70dc04196e9bJeXCHAp07]
Where Is The Father of the Flame?
You'll find this boss in an optional area called Wisp Thicket. It's one of those places that looks beautiful but is secretly trying to kill you from every angle. The enemies here love throwing exploding fireballs, so if you are bad at dodging projectiles, this area will teach you some painful lessons.
To even reach Wisp Thicket, you need the Faydown Cloak. Without it, the path up through the towers in Greymoor is closed off. Once you have it, you can climb up into this upper region and start your journey toward the boss.
Here's a small but important tip: when you arrive in Wisp Thicket, don't just rush left. First, enter the room on the right and use your needle to strike the hanging bags overhead. This releases a bench for you to rest at, which makes the runback much less annoying. Trust me, you'll appreciate that bench because the Father of the Flame fight doesn't give you reliable healing windows, so every single mask matters.
There is some platforming along the way, but you can use your Clawline to skip most enemies if you are smart about it. When you see an area marked with Bellhart colors, you are practically at the boss door. Take a breath, because things are about to get fiery.
[Image: 6a8797ac406e0dfafdedca2fd5rl99g907]
How to Prepare For Father of the Flame
This is not a normal boss where you can just equip your heaviest damage tools and mash attack. The Father of the Flame demands a specific setup, especially if you want to avoid a long, frustrating fight.
Here's the build I recommend:
Tool Slot
Recommended Pick
Why It Helps
Crest
Crest of the Reaper
Most consistent pogo crest, makes chaining pogo attacks much easier
Red Tool
Cogfly or Conchcutter
No aiming or tricky timing needed
Blue Tool
Multibinder and Reserve Bind
No silk gain during fight, so spare healing is vital
Yellow Tool
Magnetite Dice
Small chance to avoid damage, but yellow tools are not crucial here
Cogfly is my go-to red tool for this fight because it doesn't require precise aim. Conchcutter also works if you managed to claim it in the Sands of Karak. For blue tools, the Multibinder and Reserve Bind are lifesavers because you won't be gaining additional silk during the encounter. Being able to heal more from a single heal can rescue a run that's about to fall apart.
[Image: 6a8797b56852e414ffe22d7690Cph1U907]
How To Beat The Father Of The Flame
Phase One
Here's the twist: the Father of the Flame isn't just one target. The boss has five lanterns placed around the arena, and each lantern acts as a weak point. You need to platform and pogo your way around the room to hit them all. Meanwhile, explosive wisps track your position and try to blow you out of the air.
If you've upgraded your nail twice by this point, each lantern will take eight hits to clear. That may not sound like much, but when you're dodging wisps and trying to stay airborne, eight hits can feel like eighty.
A few tips for phase one:
Deal with the higher lanterns first. They're the hardest to hit safely. Once they're gone, the lower lanterns are much easier because you can drop to the floor, recover your positioning, and hop back up if needed.
Your double jump is your best friend here. Every successful pogo gives you a double jump charge back. When a wisp locks onto you, time your pogo to gain height, then use your double jump to narrowly avoid the explosion and keep attacking.
Don't obsess over one lantern. Stay adaptable. If wisps are cornering you, drop low and switch to a lower lantern instead.
Does that sound chaotic? Yes, it is. But once you understand the rhythm, phase one becomes a weirdly satisfying dance.
Phase Two
When all five lanterns are destroyed, you finally get a clear shot at the Father of the Flame's core. But don't get comfortable.
Phase two opens with the boss casting a stream of fireballs. Drop to the floor and move carefully between the gaps. You don't want to be airborne here because you'll get clipped.
Once the fireball stream stops, you have a window to hop up and attack the core. Wisps still spawn regularly, so keep an eye on their positions and use your double jump to evade them while staying on the offensive.
The boss will start the fireball attack again after a few wisps leave the field, so watch for that tell and get to the ground early. In the air, you're a sitting duck.
Finally, when the battle ends, stand clear of the boss's last explosion. It can happen after you think you've won, and if it kills you, you'll have to do the whole fight over again. Give yourself some distance, and you'll walk away with the win.
Reward For Defeating The Father of the Flame
Once this fiery customer goes down, you'll pick up the Wispfire Lantern. This passive tool uses your silk to automatically summon a wisp that acts like a homing missile, attacking nearby enemies for you.
It's a fun tool, but it has a real trade-off. Because it constantly spends your silk on offensive projectiles, healing becomes much less consistent. If you rely on silk buildup for regular heals, you might want to skip this one. But if you play aggressively and like tools that keep the pressure on enemies, the Wispfire Lantern burns brighter than most.
[Image: 6a8797bfa3f7f8d26dc867c69StFzAZL07]
So that's the Father of the Flame. It's a gimmick fight done right, at least for players who enjoy pogo combat. Stay mobile, stay calm, and don't let those wisps dictate your rhythm. Good luck out there in Pharloom!
Now that you've conquered the Father of the Flame, you might be hungry for more challenges that demand tight movement, quick reflexes, and that satisfying "one more try" mentality. Games built around precise combat and exploration don't come around often, and when one clicks with you, it's hard to put down.
If you're looking to expand your library without stretching your budget, it's worth keeping an eye on game deals today to see what else might be waiting for you. You never know when a similarly punishing but rewarding adventure will go on sale, ready to test your skills just as thoroughly as this fiery encounter did.
  How I Felt Watching Someone Beat Every Silksong Boss Flawlessly xtameembb 0 23 08-31-2026, 11:30 PM
  How I Felt Watching Someone Beat Every Silksong Boss Flawlessly xtameembb 0 50 08-29-2026, 12:39 PM
  How I Beat Lace the Second Time in Silksong xtameembb 0 54 08-28-2026, 01:04 PM
  How to Beat Father of the Flame in Silksong xtameembb 0 79 08-21-2026, 11:16 PM
  How to Beat Graol the Great in Hollow Knight: Silksong’s Brutal Bilewater xtameembb 0 129 08-08-2026, 10:00 AM
  I Beat Silksong Without a Quill and Unlocked a Purple Feather That Does Zip xtameembb 0 141 07-28-2026, 09:00 PM
