Threads: 0
0
Given 0 thank(s) in 0 post(s)
(02-24-2012, 11:43 PM)Haiduc Wrote: Evening friends... i have a question.. i 've instaled Volvo but i have the same problem as i had with the prior version:
With older cars the program is not filtering and it gives me alot of alternatives f i can call it like that. I am sure u know what i am talking about.Is there anything i can do about it?
Try insert FL or FH or F instead of A or B in chassie number letter box nr.1
Threads: 0
0
i have the same problem as amatz ...
everything works great - but not the part catalogue
if i try to search a spare part, everytime comes the same Error-Message:
Technical Error Error reference number=Error_2011-09-22_194136
(the number of Error change everytime) no drawings, no part lists !!!
can somebody help please :-)
Threads: 1
0
Thanks for uploading this one.
I'm a new forummember and i'm wondering how... uhm, how to download the Impact software. No help needed though, I'll find out myself soon enough.
Greetings!
Threads: 0
0
Any has the problem in witch images are not showned? i see codes perfectl but no images....u can imagine the pain
Any1?
Threads: 0
0
Documents how to download? thinkyou
Threads: 2
0
Given 2 thank(s) in 0 post(s)
Hi TestPoint!
Some files aren't available:
part03-28
part48
part59-60
part64-65
part90-111
part115
Please check it!
Threads: 2
0
Given 1 thank(s) in 0 post(s)
04-04-2012, 07:39 PM
(This post was last modified: 04-04-2012, 07:40 PM by chris5390.)
Problem installing IMPACT.
TT does not accept the installation (VTTCE).
do the following
1. copy the contents of the first DVD to any directory on the C :\
2. edit file config.ini
TT_BYPASS_UNSUPPORTED_VERSION = false
replace the
TT_BYPASS_UNSUPPORTED_VERSION = true
3. save
4. run the installer
Good luck :-)
Threads: 0
0
(02-29-2012, 02:05 AM)rispel Wrote: i have the same problem as amatz ...
This is also a problem, I do not know how to solve it, help!
Threads: 0
0
Threads: 2
0
Given -1 thank(s) in 0 post(s)
(03-01-2012, 08:58 PM)Haiduc Wrote: Any has the problem in witch images are not showned? i see codes perfectl but no images....u can imagine the pain
Any1?
You have to install SVG-viewer
good luck
