Daewoo Matiz Service Manual [2006]
Daewoo
[Image: image.jpg]
Quote:Year of manufacture : 2006
Author : Editorial board "By Your Own Powers"
Genre : Technical documentation
Publisher : Knizhnoe izdatelstvo "Za rulyom"
Format : PDF
Quality : Scanned pages
Number of Pages : 256
A book from a series of multicolored illustrated manuals on car repair in the home. The manual considers the device, maintenance and repair of DAEWOO MATIZ cars with a three-cylinder engine of 0.8 liters and a four-cylinder engine with a capacity of 1.0 liter. A detailed description of possible malfunctions, their causes and solutions. The maintenance and repair operations are presented in color photographs and provided with detailed comments. The appendices contain tools, lubricants, service fluids, lamps, as well as electrical equipment and tightening torques for threaded connections. The book is intended for drivers who repair the car on their own, as well as for workers of the service station.
Content:
Description of construction
Vehicle Specification
Passport data of the car
SAFETY INSTRUCTIONS FOR MAINTENANCE AND REPAIR
OPERATION AND MAINTENANCE
EQUIPMENT AND CONTROLS
Keys to the car
Doors
central locking
Tailgate
Fuel filler cap
Hood
Vehicle control and interior equipment
Ignition switch (ignition) and engine start
Instrument cluster
Control unit for heating, ventilation and air conditioning
Electric window control unit
Rear view mirrors
Switches
Headlamp Direction Controller
Interior lighting
Sound signal
Sub-switches
Shift lever (manual gearbox)
Gear selection lever
(Automatic transmission)
Parking Brake Lever
Front Seats
Backseat
Seat belts
Sun Visors
Clock
Glove box
Cigarette lighter and ashtray
Audio system
MAINTENANCE
The location of the main components and units of the car
Checking the car before departure
Maintenance schedule
Check of a condition of wheels and tires, shift of wheels
Topping up the fluid in the windscreen washer reservoir and tailgate glass
Replacing the brushes for the windscreen wipers and tailgate glass
Checking the fluid level in the brake fluid reservoir
Checking the fluid level in the power steering reservoir
Checking the engine oil level
Oil and engine oil change
Checking the coolant level
Replacing the coolant
Check and set the initial ignition timing
On a car with a 0.8 liter engine
Check of a condition and replacement of spark plugs
Adjusting the tension and replacing the pump drive belt
The hydraulic booster of a steering
Tension adjustment and generator belt replacement
Replacement of the replacement element of the air filter
Replacing the fuel filter
Checking the oil level in the manual transmission
Oil change in manual transmission
Recommendations for servicing the automatic transmission
Clutch release adjustment
Checking the technical condition of the transmission, front and rear suspension
Checking the technical condition of the steering and steering adjustment
Checking the technical condition of the brake system
Corners of installation of forward wheels
Bleeding the hydraulic drive of the brakes, replacing the brake fluid
Adjusting the direction of the headlamp beams
REPAIR IN THE WAY
Wheel Replacement
Replacement of headlight and headlight in the headlight
Starting the engine from the battery of another car
Towing a car
Car repair
ENGINE 1.0 L
Checking and adjusting the thermal clearances in the valve actuator
Checking the condition and replacing the timing belt
Oil Pressure Sensor Replacement
Replacing the camshaft seal
Replacement of a forward epiploon of a cranked shaft
Replacement of a back epiploon of a cranked shaft
Replacement of powertrain support
ENGINE 0,8 L
Check and adjustment of thermal clearances in a drive of valves of the engine of 0,8 l
SUPPLY SYSTEM
Checking the pressure in the power system
Removal and dismantling of the fuel module
Removal of a throttle knot on the car with the engine 1,0 l
Removal of a throttle knot on the car with the engine of 0,8 l
Check of the regulator of idling and the gauge of position throttle заслонки on the car with the engine 1,0 l
Check and removal of the idle speed regulator on a vehicle with a 0.8 liter engine
Removal of a fuel stage and atomizers, check of atomizers
Replacement of a cable of a drive throttle заслонки
Removing air cleaner housing
Checking and removing elements of the fuel vapor recovery system
Check and removal of elements of system рециркуляции the fulfilled gases
ENGINE CONTROL SYSTEM 1.0 L
Removing the electronic control unit
Check and replace the crankshaft position sensor
Check and replace the camshaft position sensor
Removing and testing the knock sensor
Checking and replacing the speed sensor
Checking and replacing the absolute air pressure sensor in the intake manifold
Check and replace the air intake temperature sensor in the intake manifold
Check and replace oxygen sensor
Checking and removing the ignition coil block
Check and replace the coolant temperature sensor
ENGINE CONTROL SYSTEM 0,8 L
Replacing the coolant temperature sensor
Check and replace the throttle position sensor
Check and replace the intake air temperature sensor
Replacing the cover and rotor of the ignition distributor
Removal and installation of the gauge-distributor of ignition
Replacement of optical sensor
Checking and replacing the ignition coil
COOLING SYSTEM
Replacement of thermostat
Removing expansion tank
Removing the radiator fan assembly
Removal of the pump of a cooling liquid
SYSTEM OF ISSUE OF PRODUCED GASES
Removing exhaust manifold and front catalytic converter
Removing the intermediate pipe with the rear catalytic converter
Removing the additional silencer
Removing the main muffler
CLUTCH
Removal of knots and details of coupling
Removal of a cable of a drive of deenergizing of coupling
TRANSMISSION
Replacing the drive shaft seal
Replacement of cables for selection and switching gears
Removing and installing gearbox
Replacing the front bearing of the input shaft of the gearbox
FRONT WHEEL DRIVES
Removing wheel drives
Removal and installation of the external hinge
Removal and installation of the internal hinge
FRONT SUSPENSION
Removing the anti-roll bar
Removing the Front Suspension Arm
Removing the shock absorber
Dismounting the shock absorber rack
Replacement of bearings of a nave of a forward wheel
REAR SUSPENSION
Spring removal
Removal of the longitudinal lever of a back suspension bracket
Removing the cross bar
Replacement of rear wheel bearings
Removing rear suspension
STEERING
Removing the steering wheel
Removal of an external tip of steering draft
Removal of a cover of the steering mechanism
Removal of steering draft
Removing the steering gear
Bleed the hydraulic system of the power steering
BRAKE SYSTEM
Checking and replacing the check valve of the vacuum brake booster
Replacing the brake shoes of the front wheels
Replacement brake shoe rear wheels
Removing the master cylinder
Front Wheel Brake Hose Replacement
Removal of the brake mechanism of a forward wheel
Replacing the brake disc
Replacement of the wheel cylinder of the brake mechanism of a back wheel
Removing the brake shield
Rear Wheel Brake Hose Replacement
Removing the parking brake components
Adjusting the parking brake
ELECTRIC EQUIPMENT
General information
Relay and fuse mounting blocks
- Mounting block for relays and fuses in the engine compartment
- Mounting block for relay and fuses in the car interior
Accumulator battery
- Removing the battery
Generator
- Description of the structure
- Removal and disassembly of the generator
Starter
- Removal and check of a starter
Lighting, light and sound alarm
- Removing the headlamp
- Removing the fog lamp, replacing the lamp
- Removing the front turn signal, replacing the lamp
- Removal of the lateral index of turn, replacement of a lamp
- Removing the steering column switches
- Removing the reverse light switch
- Removing the rear light, replacing the lamps
- Removing the license plate light, replacing the lamp
- Replacement of a lamp of a lantern of the additional signal of braking
- Replacement of a lamp of a plafond of illumination of salon
- Removing the sound signal
Windscreen wipers and washers and tailgate glass
- Removing the windscreen wiper
- Removing the door window cleaner
- Removal of electric pumps and windscreen washer tank and tailgate glass
Removal of a combination of devices, replacement of lamps
Removing the heater fan Removing the additional heater fan resistor
BODY
Removing the dirt guard
Removal of the front fender liner
Removing the radiator trim
Removing the front bumper
Removing the rear bumper
Removing exterior mirrors
Removing the front door trim
Removing the outer handle and the front door lock
Removal of a forward glass of a forward door
Removing the front window power window mechanism
Removing the fixed front door glass
Removing tailgate trim
Removing the lock and outer handle of the tailgate
Removing the tailgate glass
Removing the tailgate trim
Removing the tailgate lock
Removing the tunnel liner
DIAGNOSTICS OF FAULTS MOTOR AND ITS SYSTEMS
Transmission, chassis, steering and braking system
Electrical equipment
Body, heating, ventilation and air conditioning.
ANNEXES
Tools used in the repair
Tightening torques for critical threaded connections
Applied fuels, lubricants and operating fluids
Lamps used in the car
Schematics of electrical equipment
- Numbering of contacts in electrical connectors
- The scheme of starting the engine and the charge of the battery (engine 1.0 l)
- The scheme of start-up of the engine (engine 0,8 l)
- Diagram of generator connections (0.8L engine)
- Scheme of the engine management system 1.0 liter; Start
- Scheme of the engine management system 1.0 liter; continuation
- Schematic diagram of the engine management system 1.0 liter;
- Scheme of the engine management system 0,8 l; Start
- Scheme of the engine management system 0,8 l; ending
- Diagram of turning on the reverse light bulb
- Wiring diagram of braking signals
- Scheme for the inclusion of the parking light and the lamps of the license plate lighting
- Connection diagram of the relay and fuse box located in the engine compartment (1.0 liter engine); Start
- Connection diagram of the relay and fuse box located in the engine compartment (1.0 liter engine); ending
- Connection diagram of the relay and fuse box located in the passenger compartment (1.0 liter engine); Start
- Connection diagram of the relay and fuse box located in the passenger compartment (1.0 liter engine); ending
- Connection diagram of relay and fuse blocks (0.8 l engine)
- Diagram of connections of a combination of devices (the engine 1,0 l); Start
- Diagram of connections of a combination of devices (the engine 1,0 l); continuation
- Diagram of connections of a combination of devices (the engine 1,0 l); ending
- Diagram of connections of a combination of devices (the engine of 0,8 l)
- Diagram of switching on the panel lighting and instrument cluster (0.8L engine)
- Scheme of switching on the headlight and turning on the headlamp beam direction control (1.0 liter engine)
- Scheme of headlamps (engine 0.8 l)
- Scheme of switching on the headlamp directional control (0.8 l engine)
- Diagram of the inclusion of fog lamps and a fog lamp in the rear lamp (1.0 liter engine)
- The scheme of inclusion of antifog headlights (the engine of 0,8 l)
- Diagram showing the inclusion of a fog lamp in the rear light (engine 0.8 l)
- Scheme for turning indicators and alarms
- The scheme of inclusion of lamps of illumination of salon and a luggage space
- Diagram of the activation of the electric windows of the front doors
- Scheme for the inclusion of windscreen wipers and washers and tailgate glass
- Diagram of heating the tailgate glass
- Cigarette lighter and clock
- Scheme of sound system inclusion
- Diagram of the activation of the air conditioner and fan (1.0 liter engine)
- The scheme of the air conditioning and fan (engine 0.8 l)
Daewoo Matiz Service Manual [2006] TORRENT.zip
Daewoo Daewoo (Nexia+Matiz) 2008 Admin 0 3,329 07-16-2019, 03:56 AM
Daewoo Daewoo Repair Manual [2006] Admin 0 2,561 12-05-2018, 04:40 AM
Daewoo Daewoo Leganza - Service Manual [2000] Admin 0 2,555 05-06-2018, 09:49 PM
