Mercedes DAS-Xentry 09/2011 - Diagnostics for Mercedes cars
[Image: captura1u.png]
[Image: captura5p.png]
Quote:Mercedes DAS Xentry 09/2011 SDMEDIA description of the catalogue:
The program Mercedes DAS Xentry 05/2011 ( Star Diagnosis ) is intended for diagnostics of any cars of firm Mercedes. On DVD there is an information for updating data of the diagnostic device Star Diagnosis .
DVD Size : 7.15 GB
RELEASE DATE: 09/2011
LANGUAGE : Multilanguage
FOR ACTIVATIONS KEYS, PLEASE ASK HERE:
http://www.auto-epc.org/showthread.php?tid=21
DAS0911.zip
Downloaded: 362 times
Thanks for that great work. :-)
Just some "stupid" questions:
1. Does DAX XENTRY 09/2011 work also with WIS EPC 07/2011 or is it independent at all?
2. Does DAX XENTRY require a specific environment, such as IBM Thinkpad, Windows XP or whatever?
Regards,
Murguel
Hello,
I want to know how to change language after installation?
Best regards,
nbvcxw8000
(10-24-2011, 06:46 PM)nbvcxw8000 Wrote: Hello,
Best regards,
nbvcxw8000
For xentry in options .... DAS is required for a specific file!
Tell me what language you prefer and we send you private!
But language is chosen at the beginning of the installation.
Regars!
(10-22-2011, 08:48 AM)Murguel Wrote: Thanks for that great work. :-)
Regards,
Murguel
EPC is different for installation.
You must have XP Professional on your PC! They can serve other computers that have R232 serial port.Give5
I have a Panasonic CF-19 Touch! IBM T30 is very slow, you can find other computers and DELL!
The biggest problem is knowing how to configure the serial port, since the new multiplexer xentry works differently!
The best thing is to find a tutorial for the installation and it's a bit complicated from 07-2011 version!Confused
Greetings!
Ok, thank you!
I want french language.
(10-24-2011, 07:21 PM)cipolini Wrote: EPC is different for installation.
Greetings!
Thanks for your response mate.
So does not matter which Version of WIS/EPC I have installed first. I can use any Notebook with Serial Connection (RS232) and Windows XP installed. And I need to configure the Serial Parameters properly. This is the first Step to use XENTRY. That's all?
If so, thanks... that brings me a step further. :-) Great.
PS: I got a tutorioal. I know also, that the hard disk needs to get partitioned into various parts. I was just not clear regarding the versions, the operating system and Notebook type.
Greetings!
Hi
The complex is the R232 port settings! But once learned is easy! I since I have the Panasonic CF-19, IBM computers are not good, they are very slow!
Hi gents...
strange... please correct me if I am wrong:
Since Mercedes released the SD CONNECT COMPACT 4 Interface/Multiplexer, there is no need for IBM T30/60 or DELL 610/630 Notebooks anymore?
As far as I understood, the connection to the new generation of multiplexers is either over WLAN or LAN Cable, what is more effective and does not need any drivers (or RS232 Port).
That's actually great news or not? So any Notebook with WLAN or LAN Port can be used for Star Diagnosis.
And honestly: The RS232 Port is quite slow compared to LAN Cable. So I appreciate this change. The only negative is the price. While you can find the old C3/C4 Multiplexer for about 350 $ in China (as Clone), the new Generation SD COMPACT costs about 600 $.
However. I am still wondering whether DAS/XENTRY can work then with Windows 7 or do I need then to run the Application over VM Ware?
Regards,
Murguel
Hello, someone just help me to install das/xentry 09/2011 to french
(10-27-2011, 02:40 AM)Murguel Wrote: Hi gents...
Regards,
Murguel
Hello Murguel,
I have old C3 and work with VM War. and is very complicated and slowly.
Brought a lot of RAM.
I have small netbook ASUS p1005ha, but is very very slowlyHeadbang and than next crash (blue screen of death - BSoD) have only 1GB RAM and WinXP.
You have good mind with LAN cable is good and speedy work, but is only my idea.
I must find this product.
thx for good idea.
And one ask for you brothers I have Xentry 01/2011 only with EN language, but I brought CS(CZ) language.
I have all in CS(CZ) language, but DAS is in EN or CN language and I brought in CS(CZ).
I must find manual, please help me who knowsAngel.
THX.Give5
  Mercedes DAS Xentry (01.2012) - Diagnostics for Mercedes cars TestPoint 20 20,542 12-11-2012, 12:43 PM
Last Post: sukkamotton
  Mercedes DAS Xentry 11.2011 - Diagnostics for Mercedes cars TestPoint 1 3,732 02-01-2012, 08:57 AM
Last Post: kappaca
