Vediamo 5.05 [05.2014]
[Image: 346t10l.jpg]
Vediamo 5.05 (05.2014) | 3.15 GB
Quote:Version 05.2014, the original software program is designed to perform all the functions available control units of different systems. does not require any password input and codes. All features are available from the program blocks of old and new cars.
engineering functions missing in standard inzhenerki das and ksentri, especially on new models in ksentri almost nothing, and this program can very much in the new models.
briefly: coding, flash, CCN encoding (read, save, transfer to another unit), an error reading, deleting (removed from memory even those in the conventional inzhenerki not deleted), the variant encoding CCN = disable the use of systems and sensors through disabling codes encodings, and much much more ...
Extras. Information: Proven working version, CBF applied files for coding and programming for CFF.
Compatible with [Image: 282kbc.png]
Torrent file | Single Extraction | Real Screen Shots
Vediamo 5.05 [05.2014].zip
Downloaded: 11 times
