09-13-2026, 11:21 PM
Reaching the Sands of Karak in Hollow Knight: Silksong is one of those late-Act 2 milestones that feels equal parts triumph and test of patience. The area sits behind a demanding platforming route, a duo boss, and a few ability checks, so players who rush in without Clawline or a healthy supply of Rosaries will likely find themselves backtracking. The good news is that the path becomes much clearer once players understand the intended sequence: obtain Clawline in the eastern Underworks through Whiteward, travel to the Bellway Station in Blasted Steps, float down near the left wall, defeat the Great Conchflies, meet the Pinstress, and then use Needle Strike and Clawline to climb into the Sands of Karak. As of 2026, this route remains one of the most memorable and mechanically demanding stretches in Silksong's second act.
Quick Route at a Glance
Step
Action
Important Detail
1
Acquire Clawline
Found in eastern Underworks, accessed through Whiteward
2
Reach Blasted Steps Bellway Station
Head right, then down
3
Descend carefully
Float throughout the fall and stay near the left wall
4
Enter first left passage
Leads to the Great Conchflies duo boss
5
Defeat Great Conchflies
Dodge both bosses and attack when they pop up
6
Head left after arena
Glide right to the Pinstress hut
7
Talk to Pinstress
Grants Needle Strike
8
Head left for grapple point
Harpoon and use Clawline to climb
9
Take top-left passage
Continue upward while avoiding wall bugs
10
Arrive in Sands of Karak
Hit yellow balls, use corals, find Shakra
Prerequisites and Preparation
The first hard requirement is the Clawline ability. It is located inside the eastern part of the Underworks, which players can access through Whiteward. Without Clawline, the later harpoon points and vertical traversal in this route simply cannot be completed. Players should also prepare for a boss fight, because the path to the Sands of Karak passes directly through the Great Conchflies arena.
Rosaries are another consideration. Shakra sells the Sands of Karak map for 90 Rosaries, and players who arrive with an empty purse may feel stuck. Fortunately, the area is not a dead end. There are quite a few shortcuts that lead to different locations, as well as a Bellway Station. Players can use the Bellway Station to travel to an area where farming is easier, collect a substantial purse, and then return to buy the map. That makes the journey less punishing than it first appears, especially for explorers who like to bank resources before committing to a long platforming run.
The Route to the Sands of Karak
Once Clawline is in hand, players should make their way to the Bellway Station in Blasted Steps. From there, the route begins by heading right and then down. The fall is long, and control matters more than speed. Players should float throughout the fall and stay near the left wall. The first passage they come across on the left will lead them to an area where they will face the Great Conchflies.
This is a duo boss fight, so awareness is everything. Players need to watch where both bosses are coming from and dodge them while finding windows to attack whenever they pop up. Greedy hits are dangerous here; the fight rewards patience, positioning, and clean dodges more than raw aggression. After the Great Conchflies are defeated, players should head left of the boss arena.
The next section is a small but satisfying traversal challenge. Players can basically glide all the way to the right and reach the hut where the Pinstress resides. Talking to the Pinstress grants the Needle Strike ability. From there, players should head left to find a grapple point they can harpoon at. By repeatedly using Clawline to make their way up, they will eventually need to go through the passage on the top left.
The climb continues upward, and this is where the wall bugs become a serious threat. They deal two mask damage, so trading hits is a bad idea. Players should keep their movement deliberate and avoid panicking when the platforming tightens. As they progress further, they will finally reach the Sands of Karak.
![[Image: 6aa5ea016585cc171eef3c93qM4kN5O807]](https://seogc.fp.ps.netease.com/file/6aa5ea016585cc171eef3c93qM4kN5O807)
Inside the Sands of Karak
The Sands of Karak introduce a new layer of platforming built around yellow balls and coral. Players should hit the yellow ball in the area, which causes platforms to appear in front of them, as well as corals that they can down slash to make their way forward. After the second yellow ball, the platforms begin forming to the right and to the top left corner as well. The top left corner leads to a Memory Locket that players can pick up to increase the slots on their Crest. That reward alone makes the detour worthwhile, especially for players who want more flexibility in their build.
After grabbing the Memory Locket, players should head right. They will need to jump, float, and then harpoon to the wall, where they will find the yellow ball on top. Hitting the ball and going down causes platforms to form on the left. Players should then harpoon across the spikes and head up, then through the right passage. Here they will spot a new enemy. Towards the left, above them, is a room where Shakra is sitting at the end. Talking to Shakra allows players to buy the map for 90 Rosaries.
Tips for a Smoother Run
? Use Clawline patiently. The route is built around it, and rushing often leads to unnecessary falls.
?️ Respect two-mask damage. The wall bugs in the climb are not worth trading hits with.
? Farm Rosaries before the final stretch if the purse is light. The Bellway Station makes this practical.
?️ Buy the map from Shakra for 90 Rosaries. It makes later exploration in the Sands of Karak far less confusing.
? Grab the Memory Locket. Extra Crest slots are a long-term benefit.
⚔️ Learn Needle Strike. The Pinstress grants it before the hardest climbing begins.
Final Thoughts
The Sands of Karak is not just another map room in Silksong. It is a test of the movement vocabulary that Act 2 keeps expanding: Clawline, floating, harpooning, down slashing, and boss dodging all come together in one route. Players who prepare properly, defeat the Great Conchflies, speak with the Pinstress, and keep an eye out for Shakra will walk away with a new map, a Memory Locket, and a stronger understanding of Silksong's vertical design. For completionists and explorers alike, it is a journey worth taking.
Once you've conquered the Sands of Karak and are ready to dive deeper into Pharloom, you might find yourself looking for the best deals on the game, its DLC, or even a controller that can handle the precise platforming. DealNest gathers offers from across the web so you can compare prices here and ensure your next gaming purchase doesn't break the bank.
Whether you're hunting for a physical copy, a digital key, or accessories to enhance your setup, having a reliable comparison tool saves time and money. DealNest makes it easy to spot discounts and bundle deals, so you can focus on the challenge ahead rather than the checkout screen.
Step
Action
Important Detail
1
Acquire Clawline
2
3
Descend carefully
4
5
6
7
Talk to Pinstress
8
9
10
Final Thoughts
