Silksong Tools Tier List: Ranking All 59 Tools in 2026
Silksong’s tool system can feel overwhelming at first, but it is also one of the most flexible parts of Hornet’s journey through Pharloom. There are 59 Tools in Silksong, not including Ancestral Arts and other abilities she picks up along the way. Tools are split into three colors, and those colors give an instant clue about what a Tool is meant to do. Red Tools are active weapons Hornet can throw, blue Tools generally provide buffs and combat bonuses, and yellow Tools lean into quality-of-life and non-combat value. That color language is helpful, but it does not tell the whole story. A red Tool can be a game-changing boss killer, while a blue Tool might quietly carry an entire playstyle.
[Image: 69bbdc706fd58d71b002bf2fvKTo5SHK07]
Not all Tools are made equally. Some are useful no matter how someone plays, and others only shine under very specific conditions. This tier list ranks every Tool according to its general usefulness, power level, and benefits versus drawbacks. The best Tools in Silksong tend to fit any build, stay relevant across the entire game, and offer a clear benefit without a painful drawback. Meanwhile, the worst Tools can still be useful when paired with the right Crests or used in a narrow situation. That is why a tier list matters less for labeling tools as bad and more for helping players decide what to equip before a tough boss or a long exploration route.
How Tool Colors Shape a Build
Each color tells a different part of Hornet’s kit.
? Red Tools are active weapons. They can be thrown, aimed, and often create follow-up pressure.
? Blue Tools are more passive, adding combat bonuses like extra damage, improved healing, or defensive utility.
? Yellow Tools usually stay out of combat entirely, focusing on movement, map readability, and resource convenience.
Because a player can mix colors, the best setups often combine one red Tool for pressure, a blue Tool for consistency, and a yellow Tool to remove friction from exploration.
S Tier Tools in Silksong
S Tier Tools are the ones a player can slot into almost any run and forget about. They do not ask for much setup, they do not fall off in the late game, and their downsides are either tiny or easy to manage. These tools define the meta in 2026 because they make difficult fights more consistent without forcing Hornet into one narrow playstyle. A great S Tier red Tool might shred through armored enemies from a safe distance, while an S Tier blue Tool could provide a passive benefit so strong that it changes how aggressively a player can push.
A Tier Tools in Silksong
A Tier Tools are right behind the top group. They are powerful, reliable, and worth using in most runs, but they usually have a small condition attached. Some require a specific timing window, some consume a little more resources, and some only reach their full potential after the player adjusts their Crest setup. Still, an A Tier Tool is never a bad pick. It just is not as effortless as an S Tier option.
[Image: 6a9e014a95abc2ff29279437qbiTDDFg07]
B Tier Tools in Silksong
B Tier Tools are solid, but they tend to ask for more commitment. A B Tier Tool can feel amazing in a dedicated build, especially when it lines up with a player’s preferred Crests, but it may not be the best use of a Tool slot in a general exploration loadout. Players who enjoy a specific weapon rhythm or boss-killing setup will often get more value from B Tier choices than a tier list suggests.
[Image: 6a5c16159c3be8531436a742fvGgGlOp07]
C Tier Tools in Silksong
C Tier Tools usually carry a noticeable drawback or simply get outclassed by other options in the same color. They can work, but they often require more effort, more resources, or a very specific fight to feel worthwhile. For players who love experimentation, C Tier can still be fun, but for a first run they are rarely the best choice.
[Image: 6a9e01591c4b2cc8b4e095c4zj2yBKiJ07]
Situational and Worst Tools
Some Tools sit at the bottom not because they are useless, but because their usefulness is extremely narrow. They might only shine against a particular boss, in a certain biome, or when combined with a specific Crest effect. A player who knows Pharloom well can take one of these low-tier Tools and turn it into a surprising answer for a tricky encounter. However, for general play or blind exploration, they usually are not worth the slot.
[Image: 6a9e015d2c4ea6a08cad9c46qOHlW2t407]
Quick Tier Snapshot
Tier
General Feel
Best For
S
Universal power, low downside
Almost any build
A
Strong with a small condition
Most playstyles
B
Solid in a dedicated setup
Specific Crest synergy
C
Clunky or outclassed
Experimentation
Situational/Worst
Very narrow use
Specific bosses or setups
The Crest Factor
No Tool tier should be treated as final because Crests can completely change the math. A C Tier Tool that looks weak on its own can become a monster when a Crest removes its downside or doubles its effect. The reverse is also true: an S Tier Tool might not feel special if a player’s Crest choices pull the build in another direction. The smartest approach is to treat the tier list as a starting point, then test Tools against the bosses and areas that actually cause trouble.
After spending time with each Tool and finding the loadout that fits your playstyle, you may want to test those skills in other challenging worlds. Many of the best metroidvania games share Silksong’s emphasis on precision, exploration, and build variety. If you’re looking to expand your library without overspending, you can check the best game deals on DealNest to pick up similar titles at a discount. Keeping your collection fresh lets you carry the lessons learned in Pharloom into new adventures, making every Crest and Tool choice feel even more rewarding.
  TICRA Tools v23.1 manual01 0 18 11 hours ago
Last Post: manual01
  Palisade Decision Tools Suite v8.12 manual01 0 16 Today, 06:06 AM
Last Post: manual01
  Silksong Tools Tier List: Ranking All 59 Tools in 2026 xtameembb 0 18 Today, 02:44 AM
  TICRA Tools v23.1 manual01 0 20 Yesterday, 02:18 AM
Last Post: manual01
  Palisade Decision Tools Suite v8.12 manual01 0 17 09-06-2026, 10:10 PM
Last Post: manual01
  TICRA Tools v23.1 manual01 0 26 09-05-2026, 08:20 PM
Last Post: manual01
  Palisade Decision Tools Suite v8.12 manual01 0 21 09-05-2026, 12:22 PM
Last Post: manual01
  TICRA Tools v23.1 manual01 0 32 09-04-2026, 01:18 PM
Last Post: manual01
  Palisade Decision Tools Suite v8.12 manual01 0 22 09-04-2026, 08:42 AM
Last Post: manual01
  TICRA Tools v23.1 manual01 0 30 09-03-2026, 12:56 AM
Last Post: manual01
