I Tamed the Beast: How I Found and Used Hornet's Life-Stealing Crest in Silksong
I had been stuck in a cautious rhythm during my 2026 journey through Hollow Knight: Silksong. My usual setup kept me alive, but it also made every brawl feel slow. Then I read about a tool that would push Hornet into a savage, high-risk, high-reward style: the Crest of the Beast. Instead of polite swordplay, this crest grants feral claw-like attacks, extra damage, and a very tempting life-steal ability in Wild Fury mode. I instantly wanted it, but getting my hands on the crest turned into a tiny expedition through one of the game's most hostile early regions.
Why the Crest of the Beast Fits an Aggressive Playstyle
The crest is not subtle. It transforms Hornet's standard moveset into something predatory. Your attacks hit harder, and the bind mechanic changes completely. Rather than the usual recovery tool, binding with this crest triggers Wild Fury mode. In that state Hornet gains even more offensive power, and every successful strike can restore health. It is a perfect choice for players who love to stay close to danger instead of retreating.
This animalistic combat style also pairs beautifully with Silksong's combat-focused crests system. You are not locked into one identity, so I treated the Crest of the Beast as a situational weapon: a beast-mode switch for fights where aggression matters more than safe positioning.
Early Preparation: Getting the Drifter's Cloak
Before hunting the crest, I needed the Drifter's Cloak. I got it by finishing the Flexile Spines quest in the Far Fields. That reward unlocked the float ability, which is essential for reaching the crest area. If you skip this step, the route to the Chapel of the Beast becomes impossible in places.
Once the cloak was mine, I traveled to Hunter's March. My goal was the bottom-right corner of the region, where a cave mouth sits almost like a hidden invitation.
[Image: 6a9cafb34d67aed6fd37a67bXIKsD3fK07]
Entering the Chapel of the Beast
The cave led me to the Chapel of the Beast entrance, and I immediately felt the area's angry personality. Red orchids, thorns, and air currents filled the space. At first the left gate was closed, so I moved right and used the air current to float to a higher platform. That is where the real platforming test began.
[Image: 6a9cafbc4131cc6a9a19fd05gFlUUO0607]
I pogoed off the red orchids on the right, floated upward, and then let Hornet descend slowly while avoiding the red thorns on the left. The Drifter's Cloak made this feel less like a leap of faith and more like a controlled glide. Eventually I landed on the other side of the locked gate.
[Image: 6a9cafbf880bfa4acf729296Ei6WmzCz07]
A quick switch opened the gate permanently, so I could move left without repeating the whole sequence. That quality-of-life unlock was a relief, because the next room was not peaceful.
Facing the Savage Beastfly
Just beyond the gate, the Savage Beastfly boss was waiting. This fight felt like the crest's philosophy in enemy form: fast, relentless, and punishing if you hesitate. I kept my aggression short and focused on avoiding its swooping attacks rather than trying to trade hits. After it fell, the path to the left opened into a quiet chamber with a statue.
[Image: 6a9cafcc835c2bc0c5465fa3lYuPVlvO07]
I interacted with the statue, triggered the binding, and finally received the Crest of the Beast.
[Image: 6a9cafcedbd186db198e8b21AuHTwI9a07]
How the Crest Feels in Combat
The first thing I noticed was the new claw-like attack moveset. Hornet's strikes felt shorter, sharper, and more brutal. Basic enemies that previously required multiple hits started melting under the increased damage. The real joy came from Wild Fury mode. When I used the bind during combat, I stopped relying on a safe heal and instead leaned into the beast state. Every hit I landed returned a bit of health, which encouraged constant pressure.
This fits a simple but dangerous rule: the crest rewards you for staying in the fight. If you are confident enough to keep attacking, the life steal can keep you alive through encounters that would normally force defensive play.
The Downsides of the Crest of the Beast
It is not a perfect crest. After testing it across several zones, I found two big weaknesses.
First, Hornet's downward strike becomes much more angled than normal. In a game full of pogo challenges, that angled strike can make platforming sections feel awkward. The same move that helps in combat can hurt you when you are bouncing off mushrooms, spikes, or enemies over a bottomless drop.
Second, the bind change can throw off your instincts. The wild mode does not immediately heal you like a standard bind. If you are used to hitting bind as an emergency heal, you will need to unlearn that habit. Otherwise you may activate Wild Fury at low health and fail to recover because you stopped attacking.
The table below shows how I felt about the tradeoff:
Situation
Crest of the Beast performance
Dense enemy rooms
Excellent due to damage and life steal
Boss fights
Great as long as you stay aggressive
Precision platforming
Risky because the downward strike is angled
Emergency healing
Weak because bind does not instantly heal
When to Use the Crest of the Beast
My best recommendation is to switch to the Crest of the Beast right before a fight-heavy section. If a room is packed with enemies or a boss gate is ahead, equipping this crest gives you a serious offensive advantage. Once the battle is over and the path turns into a careful platforming sequence, I switch back to a more balanced tool like the Crest of the Wanderer.
That rotation helped me keep the best of both worlds: brutal damage when I needed it, and reliable movement when I did not. The Crest of the Beast became my favorite pocket weapon in Silksong, not my permanent identity. In a game that rewards flexibility, that kind of setup feels very natural.
Charm loadouts are such a personal part of the Silksong experience that half the fun is testing new arrangements between every bench. If you are planning a full run with the Crest of the Beast, it helps to know that the game itself is well worth the purchase for anyone who loves this kind of precise combat and movement. Since you will likely spend hours experimenting with these builds, snagging a good deal on the game leaves more room to enjoy every well-crafted zone without stressing over the cost.
Before you dive into Hornet's journey and start hunting down your favorite crests, it is worth checking which retailer offers the best rate for your region. You can compare prices here to make sure you get the most value out of your next adventure.
  I Tamed the Beast: How I Found and Used Hornet's Life-Stealing Crest in Silksong xtameembb 0 28 09-06-2026, 09:02 PM
  Every Mask Shard Location I Found in Hollow Knight Silksong xtameembb 0 66 09-03-2026, 07:21 AM
  Every Mask Shard Location I Found in Hollow Knight Silksong xtameembb 0 63 09-03-2026, 03:45 AM
  Ten Bosses That Will Test Hornet's Skills in Hollow Knight: Silksong xtameembb 0 78 08-29-2026, 05:17 PM
  Ten Bosses That Will Test Hornet's Skills in Hollow Knight: Silksong xtameembb 0 77 08-29-2026, 04:49 PM
  How I Found Every Crest in Hollow Knight: Silksong xtameembb 0 74 08-29-2026, 01:51 AM
  How I Found Every Crest in Hollow Knight: Silksong xtameembb 0 72 08-29-2026, 12:28 AM
  Hollow Knight: Silksong — All Seven Crest Locations and Best Playstyles xtameembb 0 82 08-27-2026, 03:07 AM
  Silksong’s Rite of Rebirth: Surviving Hornet’s Most Annoying Errand xtameembb 0 79 08-25-2026, 06:20 PM
  Silksong’s Rite of Rebirth: Surviving Hornet’s Most Annoying Errand xtameembb 0 91 08-25-2026, 02:56 PM
