Silksong Courier's Rasher Guide: Delivering Tipp and Pill's Greasy Nightmare
Let me tell you about the run that nearly made me throw my controller into Pharloom's nearest bottomless pit: delivering the Courier's Rasher from Bellhart to Choral Chambers. As of 2026, this remains one of the most gloriously awful errands in Hollow Knight: Silksong. On paper, it sounds like a charming leg of the Great Taste of Pharloom quest. In practice, it is a timed, no-fast-travel, fragility-filled escort mission for a piece of cooked meat. Hornet can leap over acid pools and duel gods, but apparently one hot breakfast is enough to humble her.
[Image: 6a9cb03c7e4f43c1f2a7ace1DqkUOkmZ07]
Before I started sprinting, I had to actually pick up the rasher. Head to Bellhart and speak with Tipp and Pill on top of Frey's shop. If those two are not there, do not panic; it just means Hornet has not rescued them yet. Finish 'My Missing Courier' and 'My Missing Brother Wayfarer' from Bellhart's Wishwall, then return. Easy enough, right? Well, the moment they hand over that greasy slab, reality sets in.
Why This Delivery Is So Cruel
Unlike Tipp and Pill's other deliveries, Courier's Rasher comes with a timer. You also cannot use fast travel, and taking heavy damage can ruin the attempt. That combination turns a simple hike into a precision parkour marathon through some of Silksong's angriest real estate. Planning matters more than reflexes here, though reflexes definitely help.
[Image: 6a9cb042ff09d570fa5d19b1004JPTA907]
The safest route I found runs from Bellhart through Shellwood, up the punishing climbs of Blasted Steps, and finally into Choral Chambers to reach Loyal Mergwin. Even saying 'safest' feels generous. Every road in this region wants to introduce Hornet to a pit or a pointy enemy.
Tools and Skills That Saved My Sanity
I strongly recommend equipping three tools before leaving:
[Image: 6a9cb043d85e29b27bf5671fMpaLVR9i07] Ascendant's Grip for wall-sticking, because slipping is death.
[Image: 6a6aa254e6c3ca205ac05ced7V1jjTGF07] Silkspeed Anklets to boost running speed.
[Image: 6a9cb044b061e43c9abeadeb6xWozMY207] Weavelight, because this run burns Silk like a campfire.
Also grab the Clawline Skill for quick hook dashes and the Faydown Cloak for double jumps. Opening every shortcut ahead of time is non-negotiable. My sneaky pro tip: open the menu map instead of using the mini-map during the run. The menu map pauses the game, giving you unlimited time to plan your next jump without the timer laughing at you. If you want to clear enemies beforehand, go for it, but do not rest at a bench after doing so unless you enjoy re-clearing everything.
The Actual Run, Step By Step
From Tipp and Pill, move right to the elevator leading to Bellhart's second floor. Exit toward Shellwood through the first exit on the second floor. In Shellwood, watch for the Gahlia flower enemy above and slash the blocking vines as you climb upward. Then it is mostly leftward running until Blasted Steps.
[Image: 6a9cb0479930bddedc3c8f82z1eOuBya07]
Blasted Steps is where the difficulty spikes harder than a nail bounce on a bell. You cannot simply avoid all threats; Hornet has to push through enemies and cage-jumping puzzles. Climb the first hole, reach the bench area, then use the shortcut platform on the right to skip the lower parkour. Leap from ledge to ledge, use the hanging bell, and when two shielded Judge enemies block the path, either jump-attack the shielded one or leap over them toward the rock on the left for a safer bell route.
[Image: 6a9cb049dbd186db198e9044i2BXDkxY07]
Keep hopping through cages, targeting bells, and bouncing onto walls. The farther you climb, the closer you get to Grand Gate. Inside Grand Gate, parkour straight up into a shortcut that dumps you directly into Choral Chambers, completely avoiding the Underworks detour. In Choral Chambers, aim for the Ventrica chamber above, but do not enter from the right side. That route is enemy soup with a side of awful platforming. Go left instead, where a hidden shortcut makes life much less miserable.
[Image: 6a9cb04c96ed373be92376b0jdkBo5es07]
After the Ventrica chamber, push through the exit that leads toward the Slab, keep moving right, and finally reach Loyal Mergwin's chamber. Hand over the rasher, let out the breath you have been holding since Bellhart, and collect your reward before any stray enemy dares interrupt.
Final Verdict
Courier's Rasher is not the hardest boss in Silksong, but it might be the most nerve-wracking errand. With the right tools, shortcuts opened, and a route that avoids the most hostile detours, the run changes from impossible to merely sweat-inducing. Just remember: the menu map is your best friend, and patience beats panic every time.
Much like scouting a route through Bellhart before committing to the run, a little homework goes a long way before you even boot up a new adventure. Hornet's quest tests your reflexes, but the real takeaway is that forethought turns chaos into a manageable path—both in Silksong and in choosing your next gaming investment. Players who appreciate that level of meticulous preparation often find themselves hunting for the next intricate Metroidvania or precision platformer before the credits even finish rolling.
When that itch strikes, stretching your coin pouch further lets you take more chances on hidden gems that deliver the same nail-biting payoff. Checking the DealNest game deals is a smart stop along that route, giving you access to solid discounts across a range of titles so your next challenge is ready to go the moment Hornet's journey wraps up.
  Silksong Courier's Rasher Guide: Delivering Tipp and Pill's Greasy Nightmare xtameembb 0 57 09-07-2026, 05:40 AM
  My Courier Nightmares and Triumphs in Hollow Knight: Silksong xtameembb 1 100 09-05-2026, 09:15 PM
Last Post: shehnaazkhan
  My Courier Nightmares and Triumphs in Hollow Knight: Silksong xtameembb 0 72 09-05-2026, 12:53 PM
