08-30-2026, 02:07 AM
If you have been poking around the Citadel in Hollow Knight: Silksong, you have probably heard about the Conchcutter, and yeah, it is every bit as nasty as it sounds. I finally grabbed it in the second act after a few very sweaty attempts, and it immediately changed how I approached stubborn bosses. It is a red Tool that ricochets off walls and drills into anything unlucky enough to stand still. Honestly, using it feels like throwing a caffeinated pinball into a glass jar and just letting physics do the violence.
![[Image: 6a9223c47327f9be545a43aag8Fh5xXU07]](https://seogc.fp.ps.netease.com/file/6a9223c47327f9be545a43aag8Fh5xXU07)
I think the biggest mistake I made was assuming the Conchcutter would be handed to me early. Nope. You need the Clawline ability and the Needle Strike from the Pinstress after the Great Conchflies fight. Without the Clawline, the Sands of Karak might as well be behind a stone zipper, because you cannot reach the upper path at all.
The Long Walk to Sands of Karak
Start from Blasted Steps and head north into the Sands of Karak. The route still holds up in 2026, although I would recommend bringing some healing items because the platforming can get prickly. Once you arrive, work your way upward with the Clawline. There are plenty of platforms that demand patience, but the geography is not hard to read.
As you climb, keep an eye out for the Stalactide. You can hit it from above to create a shortcut that will save you a horrific amount of time if you die. I hit it, watched it drop, and the whole route opened up like a bone-colored elevator shaft, which made backtracking much less annoying.
To the left of the second Stalactide is the Raging Conchfly boss arena. Do not go in lightly. Every single attack from that boss deals two mask damage, and it does not care about your feelings. Once its health gets low, it starts summoning smaller conflies that drill around the arena like angry little corkscrews. You suddenly have to split your attention between swatting minions and avoiding a giant shelled monster.
![[Image: 6a9223cda90903caa167c607EmU9SPwr07]](https://seogc.fp.ps.netease.com/file/6a9223cda90903caa167c607EmU9SPwr07)
I found it easier to stay mobile and not get greedy. The boss punishes standing still, which is ironic because once you get the Conchcutter, you become the one who punishes stationary bosses. After the fight, keep moving forward to the far end of the Sands of Karak. Head inside the Coral Tower, and the Conchcutter is just lying there on the ground. No extra puzzle, no secret door. It is a relief after that boss.
What Makes the Conchcutter So Good
The Conchcutter is a high-damage Tool that bounces off walls. If you have extra Tool Pouch upgrades, you can carry quite a few into a boss fight. Against enemies that love to plant themselves while charging a big attack, this thing is a dream. Aim, throw, and it starts drilling into the boss like a furious little excavator.
![[Image: 6a9223d59f37074e4f6f089eal97HwRI07]](https://seogc.fp.ps.netease.com/file/6a9223d59f37074e4f6f089eal97HwRI07)
I did some testing with a build, and the best combo for me was the Pollip Pouch plus the Quick Sling. That setup launches two Conchcutters at once and adds Venom to the mix. It is basically a double-barreled shell barrage, and it melts through large hitboxes. The trade-off is that you still need to manage spacing, because the Conchcutter wants walls and angles, not just a straight line.
It is also excellent for clearing obstacles in platforming sections. In Sands of Karak, while grabbing the Crustnut for the Great Taste of Pharloom, I ran into blocked paths that would have been a chore with regular attacks. The Conchcutter cleared them away in seconds. If you are exploring, keep one or two in reserve just for utility, not only combat.
Final Tip Before You Go
I will say this: do not sleep on the shortcut from the first Stalactide. You will probably revisit the area, and the climb back is not fun. With the Clawline, the shortcut, and a bit of patience against the Raging Conchfly, the Conchcutter is absolutely worth the detour. Once you have it, stationary bosses go from threats to target practice.
For players who like to be thorough, the preparation doesn't stop at in-game tools. Knowing when to buy — and when to wait — is its own kind of strategy. A quick look at a game price tracker like DealNest can show you exactly when a title drops, so your next adventure doesn't have to cost a fortune.
It's a small habit that pairs well with a meticulous play style. The same patience that helps you clear a brutal boss room can also help you land a great deal, which means more games in your backlog and less money spent chasing full-price releases.
