08-23-2026, 06:49 PM
I still remember the first time I reached the end of Hollow Knight: Silksong in 2026. I thought I had understood Hallownest's fate, but then a hidden Act 3 opened up and everything changed. Depending on my actions, quests, and the bosses I defeated before the credits rolled, I could unlock one of five different endings. Some of them were straightforward, while others demanded that I leave no stone unturned. A few even forced me to start a new playthrough because it was nearly impossible to see them all in one run. Below is what I learned after chasing every ending in the game.
How Many Endings Are There in Hollow Knight: Silksong?
There are five endings in Hollow Knight: Silksong, and each one has its own achievement or trophy. They range from normal and cursed outcomes to a true ending and an extra conclusion. The table below shows every ending I found.
Ending Name
Ending Type
Weaver Queen
Normal
Twisted Child
Cursed
Snared Silk
Bad
Sister of the Void
True
Passing of the Age
Extra
Failing to meet the unlock conditions for one ending often locked me into another. That was especially true once I discovered that some endings require reaching the hidden Act 3 of Silksong.
How to Get the Weaver Queen Ending
I earned the Weaver Queen ending, which is considered the normal ending, by defeating Grand Mother Silk and binding her at the end of Act 2. After I used the Threefold Melody to unlock the elevator in the Cogwork Core, I reached the final boss of a typical playthrough. Once she fell, I chose the prompt to Bind Grand Mother Silk. Hornet then bound her power to herself, and both she and the Citadel became wrapped up in silk. As Hornet remained in the silk bindings, she began to transform before the screen cut to black. It felt like a complete but strange conclusion.
How to Get the Twisted Child Ending
The Twisted Child ending is the cursed outcome. It also requires defeating Grand Mother Silk at the end of Act 2, but I had to be cursed beforehand through one of the Wish side quests. I nearly missed it because curing the curse or entering Act 3 would have locked me out.
To become cursed, I followed these steps:
Started the side quest called Rite of the Pollip.
Tracked down all Pollip Hearts and completed the Pollip Wish.
Found the Twisted Bud, an item located in Bilewater in a cradle made of vines.
Gave the Twisted Bud to the NPC Greyroot, a Witch located in Shellwood.
Agreed to help Greyroot after giving them the Twisted Bud.
Began the Rite of Rebirth Wish.
Allowed Greyroot to capture and ensnare Hornet.
Escaped the Chapel of the Witch.
After I completed those steps, Hornet's Silk and Needle weapon changed form, which told me a curse was lingering inside her. I then played through the rest of the game normally. I could have removed the curse by following the instructions of the character Pavo, but I kept it until Grand Mother Silk was defeated. That choice unlocked the Twisted Child ending and its unsettling cutscene.
How to Get the Snared Silk Ending
The Snared Silk ending may be the bad outcome, but it opened the door to Act 3. This was a continuation beyond Grand Mother Silk with more challenging bosses, extra levels, and far more for me to do. To unlock it, I had to complete the Silk and Soul Wish. That required four core items: The Hermit's Soul, The Maiden's Soul, the Seeker's Soul, and the Snare Setter. With those items, I talked to the Caretaker NPC in Songclave to craft the Needolin, an artifact that could help defeat Grand Mother Silk.
When I defeated Grand Mother Silk with the Needolin in my inventory, a Needolin option appeared alongside Bind. I picked the Needolin option against Grand Mother Silk to get the Snared Silk ending. That choice opened up The Abyss, the hidden third story Act.
How to Get the Sister of the Void Ending
The Sister of the Void ending is the true ending, and it only appears in Act 3. That meant I had to unlock the Snared Silk ending first. Act 3 was filled with dangerous enemies and far tougher areas, but the extra effort brought me closer to the true conclusion.
For the Sister of the Void ending, I followed these steps:
Reached Act 3 and worked through various objectives.
Defeated the boss Nyleth in the Grand Gate to get the Pollen Heart item.
Headed to the Sands of Karak area in Act 3.
Defeated the Crust King Khann boss and got the Encrusted Heart item.
Went to the Hunter's March area.
Defeated the boss Karmelita to get the Hunter's Heart item.
Started the Ritual at the Moss Grotto area.
Reached the end of the Red Memory to gain the Overbloom item.
Went to The Abyss area and defeated The Lost Lace boss.
There are plenty of hidden details in Silksong during the third Act that are easy to miss, but completing these goals helped me unlock the hardest ending in the game. The final boss of Act 3 demanded every skill and bit of effort I had.
How to Get the Passing of the Age Extra Ending
The final extra ending, Passing of the Age, also appears in Act 3 alongside Sister of the Void. To start reaching this outcome, I talked to the Fleamaster NPC in the Putrified Ducts once I was fully in The Abyss part of the story. Speaking to Fleamaster began the Ecstasy of the End Wish, which caused a platform to rise out of the water in the Putrified Ducts.
I pushed that platform until it reached the right end of the room. Then I used Hornet's grappling claw to launch upward onto some higher platforms. Climbing to the upper left brought me to a room full of mushrooms. There, I inspected a spot in the Moss Grotto to talk to someone named Mister Mushroom, who later appeared in the Bone Bottom section of the map.
Mister Mushroom showed up again in Far Fields, and then a few more times in the Grey Moore, The Slab, and Mount Fay areas. After seeing the character multiple times, I talked to them a final time at the top of the Choral Chambers to complete the Wish quest that began with Fleamaster. After that final conversation, I defeated the final boss of Act 3 to receive the fifth and additional conclusion. Unlike the others, unlocking this ending displayed a To Be Continued screen before the credits, which made me think there may be even more story still to tell.
Chasing all five endings in Hollow Knight: Silksong took time, patience, and at least one extra playthrough. Some outcomes were beautiful, some were grim, and the extra ending left me wondering what could come next. If you plan to 100% this game, keep careful track of which Wish quests you complete and be ready to enter The Abyss for the true and extra conclusions.
After unlocking every ending and truly mastering Silksong's toughest challenges, many players find themselves thinking about what to play next. Whether you are hunting for another atmospheric Metroidvania, grabbing a pre-order bonus, or just want to test a new title without overspending, it always pays to compare prices before hitting that purchase button. For those moments, taking a quick stop at DealNest can help you find the best deal across various games and accessories, so your next adventure starts without stretching your budget.
Spending dozens of hours chasing rare endings has a way of making you appreciate every little saving. A small discount on a new release or a sale on DLC can feel just as rewarding as discovering a hidden boss room. Whether you are stocking up on future playthroughs or simply treating yourself after such a long quest, checking for a solid deal before you buy is a smart habit. With the right price, you can keep your game library growing and get back to the excitement sooner.
