How Vog Helps You Find Every Lost Flea in Silksong
Pharloom’s depths have a way of hiding the tiny things that matter most. Among the many secrets woven into Hollow Knight: Silksong, the 30 Lost Fleas are easy to stumble across at first, then maddeningly easy to miss once Hornet’s map starts filling in. But there is one small soul who can turn the search from a needle-in-a-haystack ordeal into a proper scavenger hunt. His name is Vog, and he is, quite frankly, a little legend.
[Image: 6a84f49e0a20e7d040250329uCAc7g4b07]
Vog is not just another merchant. He sells a special assortment of map-focused items, and once Hornet hands over enough Rosaries, those items mark every remaining Lost Flea on the in-game map. For completionists, that is a huge sigh of relief.
Finding Vog Starts in the Putrified Ducts
Before Hornet can meet the little cartographer, she needs the [Image: 6a727f8d637050793188d38aRbhubwSS07] Faydown Cloak. This ability opens the way into Memorium near the top-right corner of the Choral Chambers, and from there she can reach the Putrified Ducts. The area sits to the right of Memorium and above Bilewater, so if Hornet is poking around those lower fungal channels, she is in the right neighborhood.
Once inside the Putrified Ducts, the next step is to head toward an elevated platform. On the left wall, there is a cracked section that can be broken. One solid smack opens the path. From there, Hornet should follow the route left and then up to reach a new screen.
Spikes, Barnaks, and One Very Tense Climb
The next screen is a teeth-gritting obstacle course packed with spikes and Barnaks. Hornet’s Swift Step ability is the key here. She can dash over the spikes and deliberately catch a Barnak’s tongue, then let the creature lift her to the next spike-filled ledge. It sounds less dignified than it looks, but it works. Those grumpy ceiling-dwellers make surprisingly decent elevators once they latch on.
Repeat the process until Hornet reaches the top, then go left. Vog is waiting there, tucked away after the gauntlet.
Meeting Vog and Bringing Him to the Caravan
After speaking with Vog, the flea announces that he is going to join the caravan. That is Hornet’s cue to make her way to the Flea Caravan stationed near Grand Gate. Once there, she will find Vog set up to the right of Fleamaster Mooshka.
This is where the real convenience begins. Speaking to Vog again lets Hornet exchange Rosaries for an assortment of items that mark any remaining Lost Fleas on the in-game map. It is a straightforward deal, and it transforms the endgame flea hunt into something far less frustrating.
Key Locations and Requirements
Requirement
Purpose
Faydown Cloak
Enter Memorium near the top-right corner of the Choral Chambers
Putrified Ducts
Reach Vog’s hidden location
Swift Step
Dash over spikes and use Barnaks to climb
Rosaries
Buy Vog’s map-marking items
Why Vog Is Worth Finding Early
Tracking down all 30 Lost Fleas without help can take an eternity. Pharloom is vertical, twisting, and full of dead ends, so having every missing flea marked on the map saves Hornet from endless backtracking. Vog may be a tiny flea himself, but his services are a big deal for anyone aiming for full completion.
In a kingdom this dense, a little map magic goes a long way. With Vog’s help, the hunt for the Lost Fleas becomes less about blind wandering and more about following a trail. For explorers determined to see everything Silksong has to offer, that kind of guidance is worth every Rosary.
Once the last Lost Flea is rounded up and the map is fully marked, that familiar itch to dive into another sprawling adventure tends to set in. Silksong is far from the only game that rewards meticulous exploration and a good sense of direction, but finding more titles like it can take a toll on the wallet if you are not careful.
That is exactly the kind of situation where having a reliable lead on affordable games pays off. Whether you are hunting for another metroidvania gem or just want to stock up on backlog material for the next rainy afternoon, knowing where to buy cheap games means you can keep the adventures coming without wincing at the checkout screen.
  Hollow Knight: Silksong Lost Lace Guide: Builds, Phases, and Void Dodging xtameembb 0 27 11 hours ago
  Hollow Knight: Silksong Lost Lace Guide: Builds, Phases, and Void Dodging xtameembb 0 28 Yesterday, 12:47 PM
  How Vog Helps You Find Every Lost Flea in Silksong xtameembb 0 49 08-20-2026, 03:06 AM
  Silksong: A Cheeky Guide to the Green Prince Quest and Lost Verdania xtameembb 0 70 08-19-2026, 04:34 AM
  Deep Docks Duo: How to Find and Flatten Forebrothers Signis & Gron in Silksong xtameembb 0 59 08-17-2026, 07:54 AM
  Deep Docks Duo: How to Find and Flatten Forebrothers Signis & Gron in Silksong xtameembb 0 62 08-17-2026, 05:26 AM
  Guide to the Steel Soul Exclusive Quest: A Vassal Lost in Hollow Knight: Silksong xtameembb 0 71 08-15-2026, 09:02 AM
  Guide to the Steel Soul Exclusive Quest: A Vassal Lost in Hollow Knight: Silksong xtameembb 0 88 08-12-2026, 05:05 PM
  I Visited the Hollow Knight: Silksong Exhibit and Discovered Pharloom’s Lost Secrets xtameembb 0 98 08-11-2026, 04:28 AM
  Exploring Lost Verdania's Dreamscape in Hollow Knight: Silksong xtameembb 0 96 08-04-2026, 04:31 PM
