08-18-2026, 03:54 PM
Fuel Gas Conditioning Systems for Clean and Reliable Gas Supply by EN-FAB Inc
EN-FAB Inc provides fuel gas conditioning systems designed to remove contaminants, control pressure, and ensure clean and reliable gas supply for turbines and industrial applications. Natural-gas processing begins at the wellhead. Raw Natural gas contains sour components such as carbon dioxide (CO2), hydrogen sulphide (H2S) and sulfur compounds, which make the gas corrosive. It also contains solid components like sand, salts, reservoir fines, drilling sludge and corrosion products and even liquid components, e.g. inhibitor and condensate. A Fuel Gas Conditioning Skid is used to prepare the fuel (gas) before use. Gas enters a scrubber or filter separator where the solids and moisture are removed. After the gas is cleaned it is usually measured, and the pressure reduced.
