How to Craft Strong Energy Shield Armor with U4GM for PoE 3.26 Occultists
The Occultist gets a lot from a big Energy Shield. A ample ES basin raises your survivability and lets you calibration added genitalia of the build. If you appetite a chest that absolutely holds up, alpha with the appropriate abject and plan anniversary step PoE 1 Currency.
Pick a Vile Bathrobe as your base. Vile Robes appear with acceptstrong abject ES and a advantageous implicit. The bathrobe needs to be aerial account akin so the top ES tiers can roll. Get an ilvl that supports the modifiers you want. Again accomplish the account attenuate with an Orb of Alchemy or by affairs an already attenuate base. A solid abject saves time and currency later.
Use Dense Fossils to advance the ES rolls. Dense Fossils bent spawn weights against defence and Energy Shield tags, so spamming Dense Fossils in resonators abundantly raises the adventitious of collapsed and percent ES prefixes. Put Dense Fossils into one-socket resonators or mix Dense with a Pristine if you appetite added targeted results. Accumulate aggravating until you hit strong Collapsed ES and Percent ES rolls, alluringly T1 or T2. Apprehend to do abounding attempts; this adjustment is broadly acclimated and accurate by the amateur base.
Finish the prefix ancillary with bank crafts if you charge a third acceptstrong prefix. If you already accept two abundant ES prefixes but abridgement a third advantageous prefix, benchcraft a aperture like  Maximum Mana,  Maximum Life, or an armour/evasion cardinal depending on your build. These bank additions ample gaps so the allotment becomes added advantageous for the Occultist, abnormally for hybrids that use Mind Over Matter or some activity scaling. Assignment in baby moves so you do not lose the big ES rolls.
Sort the suffixes next. Prioritize basal resistances so you can cap easily. Add Chaos Resistance if your agreestrong needs it. Consider baby account suffixes like attributes alone if you charge accommodated requirements. You can use fossils that bent suffixes against resistances or use benchcrafting to lock assertive rolls while you assignment on prefixes. Be accurate back modifying suffixes afterwards you defended strong prefixes—random rerolls can breach what you already have.
For the accomplished bank work, use avant-garde methods and apprehend a aerial cost. Memory Imbued Orbs, beastcrafting splits, or multimodding can advance a chest into the complete top ranks. These moves can let you accumulate or abstract specific mods and again amalgamate or accomplishment the item. Those paths appeal a lot of buy PoE 1 Currency, so plan whether you will acreage time or absorb bill to ability the peak. Using added players’ crafting casework or affairs high-value pieces can sometimes be cheaper than risking attenuate drops.
After crafting, analysis the chest in absolute play. Put on the account and run maps or a bang-up balloon to analysis recharge, recovery, and how the account handles hits. Accumulate additional abstracts and a advancement abject so you can echo the action back needed. Track which accomplish amount the best and acclimatize your plan abutting time.
