06-05-2023, 09:11 PM
If you need perform coding or parameter programming for WABCO Trailer when you use WABCO TEBS software,it will ask you to input PIN1 or PIN2.Here i will show you guide on how to install and activate WABCO PIN Calculator.
Preparation:
Wabco PIN Calculator
Steps:
Note:Before installation,please disable your anti-virus software,it will kill files.
After downloading and extracting you will get below files.
Double click “Get Hardware ID.exe” to run,then you will get your PC HWID
Sent your PC hardware ID:1051-9FEA-FA71-8042-FB72-2D05-B6DD-BB6C to our email Sales@obd2.ltd.After then i will sent you activation files like below
Drag “Wabco_PIN_p.exe” file to the activation files folder as below show
Now run Wabco_PIN_p.exe,it will show you register successfully,and click “OK” to run it
Here you can input Serial Number to calculate PIN1 and PIN2
Preparation:
Steps:
