Liebherr Lidos & Lindos EPC - Activations Keys
#71
(12-07-2011, 12:51 AM)dukim Wrote:
(09-04-2011, 03:07 AM)Alcoholahmed Wrote:
Here keys for Liebherr Lidos EPC
[Image: 2n87a4h.jpg]
here u can post ur Liehberr Lidos code....
Hello
I have problem with Liebherr Lidos code
Order code is
1g00-0000-0000-0000-4004-qon8-ondl-b20p-3edd-hh03-vq40-49vg
Please help
2e1i-ndc2-0ikf-8000-400k-4f00-00fu-l250-08
I’ve tried to install Lidos with code provided but without success.
Maybe this is because I’m trying to install Lidos 2/2011?
I’ll try to install older version 3/2010 and than over it put newer version.
Please if possible once again help me with authorization code.
New Order code given by Liebherr SEC is
1g00-0000-0000-0000-4004-qon8-ondl-b20p-3edd-hhcs-b1pu-5kg7
(12-10-2011, 08:00 AM)dukim Wrote: I’ve tried to install Lidos with code provided but without success.
6j97-ptic-v2ao-3000-400k-4f00-00fu-l250-08
[Image: Alcoholahmed.png]
Hello Alcoholahmed.
Once again no luck.
SEC is blocking installation. Gives Error 1137.
Don't know reason for not allowing installation.
Trying completely removing SEC and fresh install.
If possible please once again help me with code.
New oder code is
1g00-0000-0000-0000-4004-qon8-ondl-b20p-5da9-hjkl-mpd2-ve4b
I appologize for this and thanks.
(12-12-2011, 09:46 AM)dukim Wrote: Hello Alcoholahmed.
Once again no luck.
New oder code is
your code is:
5g22-fnv6-hf7i-5000-4000-0000-0ogi-n250-00
press "thanks" if works
Please give authorization code for LIEBHERR LIDOS 2/2011:
1g00-0000-0000-0000-400q-skdi-6aet-n5sc-1nti-hjks-dksb-7so9
(12-17-2011, 06:24 PM)elhdhd Wrote: Please give authorization code for LIEBHERR LIDOS 2/2011:
PLEASE
79fs-8k8u-l3es-4000-400k-4f00-00fu-l250-0g
PLEASE
Hello
Once again no luck.
LIEBHERR 2/2011 no LIEBHERR 2009
Please, could you give me an authorization code for LIEBHERR LIDOS EPC:
1g00-0000-0000-0000-400i-31ik-8ilp-fjhi-ad35-5kca-b5v4-78hk
Thank you
(01-09-2012, 08:06 PM)kokode Wrote: Please, could you give me an authorization code for LIEBHERR LIDOS EPC:
Thank you
hi mate.
authorisation code for you: n6jh-6dhf-i3k8-a000-400k-4f00-00fu-l250-08
don't forget press "Thank" to me.
regards.
HELP the fourm as we did , Donate NOW !
CAT CAT ET, SIS and STW - Activations Keys alcoholahmed 745 1,043,421 12-03-2017, 06:53 AM
15 Guest(s)
