MAN Mantis EPC 467 Release 05.2011
#21
(10-20-2011, 11:16 PM)MatT Wrote: Win7 64 bit instnt-new.bat
1 file(s) copied.
1 file(s) copied.
The platform is Winnt
The major version is 6
The minor version is 1
Stopping driver entry... OK
Deleting driver entry... OK
Creating driver entry... OK
Starting driver... Falied
Press any key to continue . . .
Anyone have any idea?
I have the exact same error while running the instnt-new under Safe Mode. I'm with Windows 7 x64. Tried everything! Any ideas would be most appreciated!
I met a problem of " Hardlock not found" when I completed the installation, have anybody can solve this issue? Thank you!
(10-30-2011, 08:19 PM)samchiu0811 Wrote: I met a problem of " Hardlock not found" when I completed the installation, have anybody can solve this issue? Thank you!
i have same problem please admin solve me this problem
please admin we need solve this problem soooooooooon
I apologize for the stupid question. problem solved!
Good afternoon.
I installed the program is working perfectly. I have only one problem, how do I insert a number of chassis parts and seek?
Wait for an answer soon
(11-03-2011, 04:18 AM)nightmarept0 Wrote: I apologize for the stupid question. problem solved!
Good afternoon.
Pleas we need to know about your windows
if your windows 7 we need to know about solve lockhard
thank you
Install the program on Win7 32bit and works perfectly. Unfortunately, Man Win7 64 bit doesn't work.
As far as I know, the problem is 64-bit windows, there isn't possible to install any drivers that are unsigned, and hlemu.sys that emulates hardlock is an unsigned driver - this problem don't exist in 32-bit version - hope this helps
you can not dowload it anymore? am i correct?
Seth what antivirus are you using?
  MAN Mantis EPC 472 Release 09.2011 DAMAJE 43 35,640 11-10-2012, 10:32 AM
Last Post: rashidasf
