Microcat Hyundai (09.2011)
Microcat Hyundai 09.2011 - Electronic Parts Catalog
Quote:Electronic parts catalog Hyundai. Of all models produced and / or produced Hyundai Motor Company, are divided into groups (cars, SUV / minivans / vans, commercial) and by region. The catalog can identify the vehicle by VIN (filtering part number), the search for the name of spare parts (partial or complete), original number, and also shows the applicability of parts.
There is a list of options with a transcript that facilitates selection of the right numbers in the absence of VIN-filter.
Language is possible separately for the program interface, and separately for items of spare parts.
System requirements:
800 MHz-processor or higher
256 MB RAM or more
OS: Windows
Year: 2011
Version: September 2011
Language: Multilangual
MICROCAT_Hyundai_09_2011.txt
Downloaded: 181 times
Hi, thank you for software, but can you tell me what to do with Disc 2? I know that Disc 1 is intallation, the Lekarstvo is the Pil(do I have to only copy and replace that mg16.dll or something more), but what for are those .cab file in Disc 2-how to use them?
Thanks.
Hi,very very thanks for this sit.how can i have torrent file of micro-cat Hyundai ?
because many time disconnect when i down load in any part.
I've copied the 2 files from the Lekarstvo folder but it doesn't appear to work with 64bit Windows 7.
*Update*
Confirmed not working in 64bit windows 7. It does start to load in 32bit win7, but then complains about no cd in the drive and closes again.
hey folks , if you read a little bit befor posting stupid questions...
256 MB RAM or more
OS: Windows
what does ist say to us?
this soft couldn´t run under win 7 64bit... or have you ever seen a working windows 7 pc with 800 MHZ cpu and 256 mb ram?
why everybody have this f... windows 7 to run this kind of software?
ervery soft i run until now works with windows 2000 or windows 98 or windows xp..
the clever one uses a virtual machine insted install this soft directly...
[Image: tomygurke.png]
(10-10-2011, 11:15 PM)tomygurke Wrote: hey folks , if you read a little bit befor posting stupid questions...
256 MB RAM or more
OS: Windows
Maybe you should spend a more time checking your spelling than posting useless responses to questions.....
Notice the use of the words higher and more ?? What does this tell you ??? It tells you the minimum required specs nothing else.
People buy new pcs and they come with windows 7, it's called progress.....
If you'd actually bothered to read my update you'd have noticed i tried it on win7 32 bit. That should have told you the software is capable of running on win7 32bit and that the problem is most likely crack related...
Can I get some installation instructions ?
Please Big Grin !
Installed OK on windows XP.
You have to copy the two files from "disk2" to "disk1".
After, you install Microcat.
When installation finish, you restart the computer.
After, don't open Microcat. You have to copy this files:
"mg16.dll" to X:\MCHYW\
"mg16.dll" to X:\windows\system32\
"HYWc" to X:\HYW_Data\
Now, you can run Microcat.
When program opens, you have to create a new user, and put "1" in all the fields.
Regards!![/align]
(10-14-2011, 02:13 AM)anitxu Wrote: Installed OK on windows XP.
Regards!![/align]
Thanks for that. Though the cmd file for the dll actually deletes mg16.dll from system32. I hadn't copied disk 2 into disk 1 so i'll give that a go Smile
Confirmed working on Windows 7 Smile
tomygurke you're an idiot.....
Hyundai Microcat Hyundai [08.2018] Admin 0 3,605 10-18-2018, 01:22 AM
Hyundai Microcat Hyundai [08.2018] Thunder 1 4,834 09-27-2018, 04:40 PM
Last Post: tikchak
Hyundai Microcat Hyundai [01.2017] Thunder 0 3,850 02-23-2017, 02:13 AM
Hyundai Microcat Hyundai [01.2017] Admin 0 2,840 02-01-2017, 04:27 AM
Hyundai Microcat Hyundai [10.2016] Admin 0 3,164 11-29-2016, 03:40 AM
Hyundai Microcat Hyundai 03.2016 jahacmm 1 3,820 09-21-2016, 04:00 AM
Last Post: ahmednsry
Hyundai Microcat Hyundai 2015/12- 2016/01 jahacmm 0 3,408 01-17-2016, 09:55 PM
Last Post: jahacmm
Hyundai Microcat Hyundai [10.2015] Thunder 0 3,322 10-28-2015, 06:56 AM
Hyundai Microcat Hyundai [08.2015] Admin 0 2,382 08-28-2015, 12:10 AM
Hyundai Microcat Hyundai [08.2015] Thunder 0 2,442 08-22-2015, 12:59 AM
