MAN Mantis EPC 467 Release 05.2011
MAN Mantis EPC 467 Release 05.2011 - Electronic Spare Parts Catalogue
[Image: captura0m.png]
[Image: captura1dq.png]
[Image: captura2yid.png]
[Image: captura3i.png]
[Image: captura4v.png]
[Image: captura5e.png]
[Image: captura6.png]
Quote:Man Mantis electronic spare parts catalogue presented spare parts for trucks Man, buses Man, engines MAN.
The new versions of the program allows to enter complete VIN of the machine for identification, but defines by VIN only model and date of release. There is a search of figure by original number of a detail and list of automobiles, where the detail was applied, also replaced numbers of details both new and old. For search of spare parts of the concrete machine it is necessary to know VIN or precisely to know model, wheel formula, interaxial distance, type of a suspension and cabin, also the type and modification of the engine installed on the machine. The search by VIN in the program is realized as follows. It is possible to enter complete VIN or to use with 4 till 6 symbols VIN for definition such as (up to five symbols enter the zero) and with 7 till 10 symbols for definition of number of chassis, also it is possible to choose a type and number the chassis from the list of possible variants. All other data to specify require search directly on the machine.
The abbreviation MAN - means Machine-building factories Ausburg and Nuremberg. The firm "MAN" is based in 1915 and is one of the biggest manufacturers of vehicles, including buses and also components for their assembly (axles, transmissions, engines, cabins).
DVD Size: 1.36 GB
Languages: English, Hungarian, Dutch, Danish, Spanish, Italian, Chinese, German, Dutch, Norwegian, Polish, Russian, Romanian, Turkish, French, Czech, Swedish, Japanese
OS: XP, Vista, 7
Version: 467
Release Date: 05/2011
Medicine: Yes
_____________________________________________
TESTED on Win7 Ultimate 32 bit - Enjoy ALL Wink
MAN.Mantis.EPC.467.Release.05.2011.txt
Downloaded: 349 times
First at all, thanks on this post. But I have problem with update, it show's me massage 'Update expire'. How to update MANTIS, please?
Thanks!
Hello, big thanks for upload.
nipon
Did have the same problem, it's something with the hardlock emulation. The only way to overcome this problem is to uninstall Mantis, Hardlock and HLEMU (running delnt.bat in CRACK directory). Delete C:\MANTIS directory, and C:\WINDOWS\mantis.ini and then running "regedit" and search for words:
mantis hardlock hasp lexcom
deleting all keys with them. And then do the clean Installation and it should work fine.
I hope this will help.
I did find strange behavior in Mantis working - after 2 or 3 weeks it starts to search longer and when searching for one thing and then going for something else it shows the image from firs item but without parts listed below, then i do this delete procedure and it works perfectly for another 2 or 3 weeks - does someone had the same problem?
Net installation also does not help. Just run the application through the system date back to 2007.
Somebody can help me? I've installed mantis'11 and when i open the application appears : Error7:Hardlock not found. Also hen i run instnt-new.bat a DOS window opens and appear: Acces denied!
Please help! Thanks!
You have another Hardlock resident in your memory. Uninstall it then use the hardlock of Mantis.
The same thing happens to me, its a virgin Win 7, i dont have anything else installed there wich needs hardlock. Any ideas? Confused
(09-17-2011, 08:09 PM)marius.babei Wrote: Somebody can help me? I've installed mantis'11 and when i open the application appears : Error7:Hardlock not found. Also hen i run instnt-new.bat a DOS window opens and appear: Acces denied!
Impossible. The screenshots are from Win7 Smile
You must read the instructions before installing !
I did everything like you've described in that readme file, its the easiest installation guide anyways Smile But still, when i hit the instnt-new.bat instead of those things described there, its "access is denied". Those files has to be copied somewhere?
(10-07-2011, 06:43 PM)TestPoint Wrote: Impossible. The screenshots are from Win7 Smile
Open the batch file with Notepad and you'll see the path Smile
  MAN Mantis EPC 472 Release 09.2011 DAMAJE 43 35,712 11-10-2012, 10:32 AM
Last Post: rashidasf
