  • 2 Vote(s) - 4 Average
PEUGEOT Service Box EPC + SEDRE (11/2010)
#21
start docbackup & sedre
[Image: 0000111.png]
Screen of docbackup will open,choose car.
[Image: 1111.png]
[Image: 222222.png]
[Image: 3333.png]
New window will open (sedre)
[Image: 4444.png]
[Image: 5555.png]
sedre will ask to insert dvd1 (mount dvd1)
[Image: 6aaaa.png]
[Image: 777.png]
[Image: 8888.png]
[Image: 9999999.png]
i will try this tomorrow in office.. but i remember that it looks different at my pc ...
which version you use? 11/2010 ?
[Image: tomygurke.png]
I believe its an early 2010 version.
docbackup version: v2.8.21.0
problem of working:
hello,
i install 3 times both of the two programs, the installation is ok an when i want to start peugeot or citroen, it doesn t works .
the connection seems to be bad for the progs but it was good, an other time it was expired ( i found something to give it good for 20 years) and peugeot was good, after i put citroen an each of them was hs....Headbang
can someone tell me how he did to install on xp pro, about mac adress and all you think can be interesting to solve my problem....Idea
Hello members:
Thanks very much for software. But I have a problem. I can't install it. I double click on Setup.exe and the Setup does not start. Do any of you have this problem ??
Thanks
Nobody have this problem Smile
- Use CCleaner and clean all your PC ..
- Also open a text file and save this lines as Clean.bat
Quote:@echo off
del /s /f /q %windir%\temp\*.*
rd /s /q %windir%\temp
md %windir%\temp
del /s /f /q %windir%\Prefetch\*.*
rd /s /q %windir%\Prefetch
md %windir%\Prefetch
del /s /f /q %windir%\system32\dllcache\*.*
rd /s /q %windir%\system32\dllcache
md %windir%\system32\dllcache
del /s /f /q "%SysteDrive%\Temp"\*.*
rd /s /q "%SysteDrive%\Temp"
md "%SysteDrive%\Temp"
del /s /f /q %temp%\*.*
rd /s /q %temp%
md %temp%
del /s /f /q "%USERPROFILE%\Local Settings\History"\*.*
rd /s /q "%USERPROFILE%\Local Settings\History"
md "%USERPROFILE%\Local Settings\History"
del /s /f /q "%USERPROFILE%\Local Settings\Temporary Internet Files"\*.*
rd /s /q "%USERPROFILE%\Local Settings\Temporary Internet Files"
md "%USERPROFILE%\Local Settings\Temporary Internet Files"
del /s /f /q "%USERPROFILE%\Local Settings\Temp"\*.*
rd /s /q "%USERPROFILE%\Local Settings\Temp"
md "%USERPROFILE%\Local Settings\Temp"
del /s /f /q "%USERPROFILE%\Recent"\*.*
rd /s /q "%USERPROFILE%\Recent"
md "%USERPROFILE%\Recent"
del /s /f /q "%USERPROFILE%\Cookies"\*.*
rd /s /q "%USERPROFILE%\Cookies"
md "%USERPROFILE%\Cookies
- Run the Clean.bat file and wait untill the opration finish
- Restart your PC
- Mount the DVD1
- Run Setup.EXE
- Wait for some moment the instalation will start
Hello Admi
Thanks very much. I followed your instructions but my problem is the same. After double-click on setup.exe a little window with the message " Please wait" appear, but nothingelse happen. 39
Do you other idea to solve it ??
thanks
Finally I solved it, just erase the register manually (CClean and clean.bat did not work).
Clean in register BackupAP and DocBackup.
Now I have another problem, it does not Run. I double-click on PeugeotDocBackup Icon and I have the following error message:
Fatal error : Installed application is out of date, please update it
Any ideas ??
Hi members:
I solved my problem and now I can open PeugeotDockbackup. For others members like tomygurke with the same problem, the solution is replace Infos files in the C:\Program files\DocBackupAP\resources with the files here attach.
It works for me, I hope it works for you.
I can open PeugeotDockbackup, but if I double-click in PeugeotSedreBackup nothing happend, Does PeugoetsedreBackup must open ??
DataExtend.txt
Downloaded: 47 times
  Citroen Service Box (DocBackup + Sedre) (11.2013) TestPoint 0 6,058 03-13-2019, 06:23 PM
Last Post: TestPoint
  Peugeot Service Box (DocBackup + Sedre) (11.2013) TestPoint 0 5,747 03-13-2019, 06:20 PM
Peugeot Peugeot Service Box Documentation Backup + Sedre (11.2012) TestPoint 3 8,296 03-08-2013, 05:21 PM
Last Post: Creeping_Back
Peugeot Peugeot Service Box Documentation Backup [05.2010] wacko 2 4,329 10-24-2011, 05:16 PM
7 Guest(s)
