Smart Forum
Facebook
Auto-Software
Auto-file.ORG
EPC SOFTWARE
Support US
- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
MAN Mantis EPC 467 Release 05.2011
Threads: 0
0
Given 0 thank(s) in 0 post(s)
(10-07-2011, 06:49 PM)seth Wrote: I did everything like you've described in that readme file, its the easiest installation guide anyways But still, when i hit the instnt-new.bat instead of those things described there, its "access is denied". Those files has to be copied somewhere?
(10-07-2011, 06:43 PM)TestPoint Wrote: Impossible. The screenshots are from Win7
You must read the instructions before installing !
If you are using Win7, disable UAC first before installing.
And run instnt-new.bat with Administrator account.
I encountered the same problems before and solved it like this.
Threads: 0
0
win 7 instnt-new.bat error
Access is denied.
0 file(s) copied.
Access is denied.
0 file(s) copied.
'wdreg' is not recognized as an internal or external command,
operable program or batch file.
Press any key to continue . . .
HELP
Threads: 1
0
(10-08-2011, 04:50 PM)renesis Wrote: (10-07-2011, 06:49 PM)seth Wrote: I did everything like you've described in that readme file, its the easiest installation guide anyways But still, when i hit the instnt-new.bat instead of those things described there, its "access is denied". Those files has to be copied somewhere?
thanksssssssssssss good point
Threads: 1
0
Threads: 0
0
Good work
Threads: 0
0
Win7 64 bit instnt-new.bat
1 file(s) copied.
1 file(s) copied.
The platform is Winnt
The major version is 6
The minor version is 1
Stopping driver entry... OK
Deleting driver entry... OK
Creating driver entry... OK
Starting driver... Falied
Anyone have any idea?
Threads: 1
0
Try it under SafeMode. But as far as i remember, this was the error given under safemode, but still, the program is working perfectly.
(10-20-2011, 11:16 PM)MatT Wrote: Win7 64 bit instnt-new.bat
1 file(s) copied.
1 file(s) copied.
Threads: 0
0
Only this is not the solution to the problem, because every time I will want to run the program, I will have to restart your computer and enter SAFE MODE.
Threads: 1
0
I didnt say that. I ran the crack under safe mode, gave me the same error like yours, but after entering normal windows mode, the program was running perfectly.
(10-20-2011, 11:57 PM)MatT Wrote: Only this is not the solution to the problem, because every time I will want to run the program, I will have to restart your computer and enter SAFE MODE.
Threads: 0
0
10-21-2011, 05:00 PM
(This post was last modified: 10-21-2011, 06:01 PM by MatT.)
Unfortunately, running crack in safe mode nothing could. Next the same problem. What you have Windows 7 32bit or 64bit?
| Users browsing this thread: |
9 Guest(s)
