ACTIA Multi-Di@g v39.31 [I-2017]
Diagnostic tool
![[Image: 01.jpg]](https://i.postimg.cc/5NTMY64x/01.jpg)
![[Image: 02.jpg]](https://i.postimg.cc/HLCDzR8R/02.jpg)
![[Image: 03.jpg]](https://i.postimg.cc/3wCMc1gR/03.jpg)
![[Image: 04.jpg]](https://i.postimg.cc/P5DnmTJ1/04.jpg)
Diagnostic tool
Type: Diagnostic tool
Year: 2017
Date of update: I/2017
License: High
The Express Diag feature lets you run a comprehensive test across all ECUs in the vehicle in just 1 click. This feature lets you check the vehicle’s electronic status in a few minutes and then prints out a Diagnostics Report. This Diagnostics Report is automatically customisable with your workshop name and details, lists the ECUs tested and gives a detailed rundown of ALL errors identified.TORRENT FILE| Single Extraction | Real Screen Shots
