Actia MultiDi@g v32.05 [II-2014]
Diagnostic tool
![[Image: 01.jpg]](https://i.postimg.cc/6qQNRZ4Q/01.jpg)
![[Image: 02.jpg]](https://i.postimg.cc/C17gz71t/02.jpg)
![[Image: 03.jpg]](https://i.postimg.cc/ydsK1tVc/03.jpg)
![[Image: 04.jpg]](https://i.postimg.cc/TPrGXfXT/04.jpg)
Diagnostic tool
Type: Diagnostic tool
Year: 2014
Date of update: II/2014
License: HighIdeal for the independent garage wanting a truly multi-make diagnostic tool giving in-depth diagnostics on a wide range of European-manufactured cars.
The Express Diag feature lets you run a comprehensive test across all ECUs in the vehicle in just 1 click. This feature lets you check the vehicle’s electronic status in a few minutes and then prints out a Diagnostics Report. This Diagnostics Report is automatically customisable with your workshop name and details, lists the ECUs tested and gives a detailed rundown of ALL errors identified.TORRENT FILE| Single Extraction | Real Screen Shots
