It only works with Noregon DLA adapters as a fully functional scan tool for medium, light and heavy duty Class 8 trucks, the heavy duty option works with all PR1210A, B and C interfaces, It does not work with Noregon It interface drivers up to 4 supported operating systems are working properly, conflicts may also occur, such as DPA drivers causing software crashes, or installing all 3 nexiq USB links, resulting in missing WIFI options and connection issues Hardware requirements: 1.Minimum: 4GB RAM, 20 GB of available hard drive space, at least an Intel Core i3 processor and minimum of a 1024×768 sized monitor 2.Recommended: 8GB RAM, 20 GB of available hard drive space, Intel Core i5 processor 3.USB port for DLA+ 2.0 adapter or other RP1210C-compliant vehicle adapter 4.Noregon recommends using a Panasonic Toughbook, but JPRO will work on any current PC running Windows 8 or Windows 10
5.Only the Noregon DLA+ 2.0, DLA+ 2.0 Wireless, Trailer Diagnostic Adapter, DLA+, DLA+ Wireless, and DLA+ PLC adapters are supported.
Noregon's JPRO Professional 2025 V1 Update includes enhanced off-highway support and expanded OEM coverage with bidirectional tests for Detroit engines and Detroit Assurance, along with new Bendix features like estimating brake wear life for pads and rotors. There is also a new virtual connection, similar to Virtual Truck, where technicians can simulate diagnostics on off-highway equipment
Key Concepts in Vehicle Diagnostics
Understanding Vehicle Connections
Live medium-duty vehicle connections are crucial for real-time diagnostics and troubleshooting.
The 'Connector Info' page in JPRO displays the status of connections, including blinking pins that indicate active communication with the vehicle.
Proper understanding of these indicators is essential for effective diagnostics.
Importance of Active Communication
Active communication between the diagnostic tool and the vehicle is necessary for accurate data retrieval.
Blinking pins signify that the diagnostic tool is successfully communicating with the vehicle's onboard systems.
This communication allows technicians to access fault codes, live data, and perform various tests.
