ACTIA Multi-Di@g [IV-2013] - Printable Version
+-- Forum: The Smart Forum (https://www.auto-epc.org/forumdisplay.php?fid=26)
+--- Forum: The Smart Forum (https://www.auto-epc.org/forumdisplay.php?fid=27)
+---- Forum: General - Aftermarket (https://www.auto-epc.org/forumdisplay.php?fid=43)
+----- Forum: ACTIA Multi-Di@g (https://www.auto-epc.org/forumdisplay.php?fid=72)
+----- Thread: ACTIA Multi-Di@g [IV-2013] (/showthread.php?tid=4647)
ACTIA Multi-Di@g [IV-2013] - Admin - 12-01-2014
Actia MultiDi@g v30.21 [IV-2013]
Diagnostic tool
Type: Diagnostic tool
Date of update: IV/2013
License: High
Quote:Ideal for the independent garage wanting a truly multi-make diagnostic tool giving in-depth diagnostics on a wide range of European-manufactured cars.
Multi-Diag guides the operator step by step through the job ahead Confusedervicing, wheels and suspension, brakes, air conditioning, anti-pollution, car body, and engine. The workshop mode lets you perform bull’s-eye diagnostics every time.
