ACTIA MultiDi@g IV-2013 (30.06) - Printable Version
+--- Forum: General - Aftermarket (https://www.auto-epc.org/forumdisplay.php?fid=10)
+---- Forum: ACTIA Multi-Di@g (https://www.auto-epc.org/forumdisplay.php?fid=256)
+---- Thread: ACTIA MultiDi@g IV-2013 (30.06) (/showthread.php?tid=4494)
ACTIA MultiDi@g IV-2013 (30.06) - TestPoint - 01-07-2014
Quote:Ideal for the independent garage wanting a truly multi-make diagnostic tool giving in-depth diagnostics on a wide range of European-manufactured cars.
Multi-Diag guides the operator step by step through the job ahead Confusedervicing, wheels and suspension, brakes, air conditioning, anti-pollution, car body, and engine. The workshop mode lets you perform bull’s-eye diagnostics every time.
TORRENT FILE
