Choral Chambers Guide: Finding the Map and Best Rewards - Printable Version
+--- Thread: Choral Chambers Guide: Finding the Map and Best Rewards (/showthread.php?tid=28825)
Choral Chambers Guide: Finding the Map and Best Rewards - xtameembb - 09-08-2026
Choral Chambers in Hollow Knight: Silksong is not the cruelest slice of Pharloom, but it has a special talent for making a player feel gloriously lost. One moment they are pogoing off a bell like a tiny, needle-wielding maestro; the next they are staring at the same rectangular room for the fifth time. Is the area actively hostile? Absolutely. Is it also full of rewards, shortcuts, and a few delightful side quests? Equally true. For anyone determined to clear this late-game zone without losing their mind, the first order of business is tracking down the actual map.
[Image: 6a9e0138df231515ed9bd7554bHDeiy907]
The Map Hunt: A Bell-Fueled Odyssey
Starting from the bench just north of the Underworks is the sanest approach. If that bench has not been unlocked yet, a player should head southwest inside Choral Chambers until they tumble into a large rectangular room with a single downward exit to the west and another exit at the lower right. Taking the latter leads to a short corridor with a bench—sit down, save, and take a deep breath, because the real navigation begins now.
From that bench, the route heads west into a large rectangular room. Hug the left wall until a hole in the floor appears. Just to the right of that hole sits a small platform. A few wall jumps later, a corridor opens on the right. The trick here is not to panic as the rooms begin to blur together.
After running down the corridor and wall jumping into a higher room, the player passes an alcove decorated with Rosaries on strings. This is not a suggestion to grab everything in sight; it is a welcome sign that the upward climb is still correct. Continue upward, then head immediately right on the next screen.
Enemies in the following room can be fought or ignored. At the very end, attacking a lever opens a hole in the floor. Dropping through, continuing right, and curving back up leads to a higher platform. On the left side, another lever opens an exit into the room above. Attack it, jump up, and run right. Then, in the next room, avoid the enemies and slip out the right exit.
Now for the fun part: pogo jumping up the bells and platforms. It looks like a musical instrument, and yes, it can absolutely kill. A secluded passage waits on the right, leading to a room full of spinning gears. Platform over them, then drop all the way down the vertical section while avoiding the spikes on the right side. The glide ability earns its keep here. At the bottom, follow the sign toward the Bellway station, pass the Bell Beast, and rest at the bench. A machine at the end of the corridor will happily sell the Choral Chambers map for 70 Rosaries.
Why 70 Rosaries? Perhaps because the cartographer knows exactly how desperate lost bugs can get.
Choral Chambers’ Greatest Hits: Benches, Side Quests, and Upgrades
[Image: 6a9e0142a063ae228ea4baa1ANAYKDrc07]
With the map in hand, the area reveals itself as more than a maze. The most important stop is the Songclave at the northeastern edge. There, a Wishwell offers The Wandering Merchant sidequest, which sends one after the wayward Jubilana. She is tucked away near the bottom-middle of Choral Chambers. From Citadel Spa, head right, drop to the bottom of the room, exit right, then turn around and use the exit just below and to the left. Rescuing her causes Jubilana to set up shop at the Songclave.
Her inventory includes the Ascendant's Grip and Spool Extender tools, plus a Mask Shard. If a player then completes The Lost Merchant from the Wishboard, her inventory expands even further. Collectors should also keep an eye out for two lost fleas: one in the northeast part of the room near Jubilana, and another in the northeast corner of the Songclave itself.
Though no proper boss battle guards the Choral Chambers, an Arena Battle sits just west of Citadel Spa. Four waves of enemies provide a solid test of Hornet's tools and patience.
Location
What's Worth Noting
Songclave
Wishwell, Jubilana's shop, lost flea
Near Citadel Spa
Arena Battle, Jubilana's hiding spot
Bellway station
Map vendor, bench
West of large vertical room
Bench near Cogwork Core
Northwest near High Halls
Bench
Choral Chambers also acts as a hub of exits. It connects directly to The Slab, Cogwork Core, The Cradle, and Memorium. Anyone hoping to avoid a return trip should deal with these routes while the benches are fresh and Rosaries are plentiful.
So, is Choral Chambers worth the headache? For map completists, tool collectors, and anyone who simply cannot stand an unexplored corridor, the answer is a resounding yes. It may not be the hardest area in the game, but it certainly knows how to make an entrance—and a very long exit.
For those who have yet to dive into Hornet's adventure, the promise of intricate, interconnected spaces like Choral Chambers is exactly the kind of content that makes the wait worthwhile. If you haven't already secured your copy of Hollow Knight: Silksong, keeping an eye on pricing can pay off—especially since launch discounts and seasonal promotions tend to appear without much fanfare. A reliable steam sale tracker can alert you the moment the game drops in price, ensuring you are ready to explore every gear-turning corner and hidden bench without overspending.
Armed with a full map, a stocked inventory, and a well-timed purchase, you can focus on what truly matters: uncovering every lost flea, claiming every tool upgrade, and finally watching that last unexplored corridor fade from your cartographer's chart.
