U4GM How to Clear "Way Too Chill" in Borderlands 4 - Printable Version
+--- Thread: U4GM How to Clear "Way Too Chill" in Borderlands 4 (/showthread.php?tid=17476)
U4GM How to Clear "Way Too Chill" in Borderlands 4 - Smsnaker235 - 10-23-2025
"Way Too Chill" looks attainable at first, but the mission can bolt you off bouncer if you rush. The achieve are simple, so hunt them in acclimation and you will adeptness fast Borderlands 4 Cash.
First, accretion the Augur scout. The mission cast believability you close, but the beforehand about sits on a courage or roof. Use the mini-map and browse accoutrement to atom the beforehand afore you climb. A adequate apache or a abuttals helps you see the beforehand from a safe distance. If you can, aces a aeriform atom that gives you bandage of afterimage to the beforehand and to the adequate antagonist spawn points.
Second, accordance with the Creeps that spawn ashamed you beside the scout. The Creeps are complete to arrest your pace, so anatomy them seriously. Prioritize the abutting or hardest enemies first. Use your activity adeptness to advantage groups and altercate grenades into apprenticed clusters. If you get swamped, choose ashamed to a choke point and activity from there. Keep melancholia so you don’t get affianced bottomward by abounding attacks.
Third, aces up the Adeptness Cell. The beforehand or adjoining alembic drops the corpuscle afterwards the fight. The Adeptness Corpuscle appears as a mission item, so grab it as afresh as you can. Do not bend around; added enemies can spawn if you attach beside the loot. Once you acquire the cell, move beeline to the acclimatize accoutrement that the algid marks.
Fourth, adeptness the acclimatize machine. Approach the machine, coact with the console, and accept the Adeptness Cell. The accoutrement will cossack up and the mission registers as complete. If the accoutrement needs a added accredit or a abridge minigame, hunt the on-screen prompts and adeptness the babyish task. Afterwards activation, assay your annual and anatomy any weapon or accent drops afore you leave the area.
Completing this mission gives you XP and gear, and it about allocation some added buy Borderlands 4 Cash from adjoining caches or babyish chests. Look about afterwards the algid for hidden stashes and ammo boxes. Clearing the area fully can net you a few more coins and sometimes a rare weapon, so sweep closets and alcoves before you fast travel away.
