Using the Nexiq USB-Link 3 for Diagnostics
Nexiq USB Link 3 Wired Edition with Diagnostic Software and Repair Information
Designed for flexibility, the USB-Link 3 Wireless Edition connects to your PC, tablet, or smartphone via Bluetooth and Wi-Fi.
NEXIQ 3 Features:
1. Support system: XP and windows 7 (Volvo Hino Perkins Cat Nissan software must be used on xp system, other software can be used on win 7 32bit)
2. It Works As Great As Nexiq.
3. Compatible with applications that diagnose engines, transmissions, ABS, instrument panels and more.
4. Reduce reprogramming times with direct USB connection.
5. Mixed fleet capabilities with broad protocol support.
6. Quick access to vehicle data for maintenance or management reports.
7. Quickly attaches to vehicle's diagnostic connector.
8. Easy portability increases flexibility, May be used with desktop PC or laptop.
Performing Diagnostics: With the software configured, you can now perform various diagnostic tasks. These can range from reading and clearing fault codes, monitoring live data from different sensors and systems, performing automated tests, and configuring vehicle parameters.
ECU Programming and Service Tests: Although you haven’t programmed any ECUs yet, the Nexiq USB-Link 3 is capable of facilitating this, along with other service tests, provided the software application supports these features. Always ensure you follow the software’s guidance and the vehicle manufacturer’s procedures when performing these advanced tasks.
Using With J1939 and Other Protocols: Your setup includes testing communications with an engine J1939 single channel simulator, demonstrating the device’s capability to interact with various vehicle communication protocols. Ensure your diagnostic software is set up to communicate over the correct protocol for the vehicle or system you are diagnosing.
  Compatibility Fix for NEXIQ USB LINK 3 and ALLISON Software Paul Zagata 0 185 10-28-2024, 12:08 AM
Last Post: Paul Zagata
  NEXIQ USB Link 2 or 3? Paul Zagata 0 565 07-09-2024, 12:16 AM
ZZ.Blank NEXIQ USB Link 125032 Interface Thunder 0 2,897 08-30-2015, 08:53 PM
