BRP Bombardier Diagnostic Kits, MPI-3 for BUDS / BUDS-2 / DIUS4 + Licenses
BRP Dealers Diagnostic Kit - $755
What included:
  • BRP MPI-3
  • BRP Diagnostic Cable (for connection of MPI-3 to 4-TEC/E-TEC technique)
  • BRP BUDS Diagnostic software (supports BRP till 2016)
  • BRP BUDS-2 License Mechatronic Expert for 1 year (supports BRP from 2016 and up)
  • Remote installation BUDS
  • Remote installation BUDS-2 + Configure drivers
BRP Mechatronic Expert Diagnostic Kit - $899
What included:
  • BRP MPI-3
Both kits supported BRP vehicle:
  • Sea-Doo PWC from 2002 till current
  • Sea-Doo SPORTSBOAT from 2002 till the end of BRP production
  • Ski-Doo from 2005 till current
  • Lynx from 2005 till current
  • Can-Am ATV / SSV from 2004 till current
  • Can-Am Spyder / Ryker from 2007 till current
Language support in software: English, German, Spanish, French, Italian, Norwegian, Portuguese, Finnish, Svenska, Russian, Chinese, Japanese
Main functions:
  • Reset TPS to zero position
  • Read Fault Codes along with fault data
  • Erase Fault Codes
  • Reset Maintenance Light
  • Reset Service Hours
  • Reset Service Rental Hours
  • Change of owner’s information and the updating of purchase date.
  • Combine Clusters to ECU's
  • Key programming (adding / removing / changing)
  • Real-Time Engine Monitor (Last 30 or 60-sec history, activate fuel pump, spark plugs, cluster WOW effect, others)
[Image: BRP-Kit.jpg]
BRP Bombardier BUDS/BUDS-2/DIUS-4 MPI-3 Diagnostic VCI - $435
[Image: BRP-MPI-3.jpg]
BRP Skidoo Power Interface - $175
  • BRP strongly recommends the use of the power interface and power supply cables to stabilize the unit voltage when using BUDS & BUDS2 during software updates.
  • The power interface and power supply cable allow the connection of a fully charged external battery to provide stable voltage to the unit and BUDS / BUDS2. Stable voltage is essential to prevent update crashes
  • The power interface and the power supply cable connected to the external battery can be used for extended diagnostic time
  • The power interface with or without the power supply cable will keep the unit powered even if the ignition switch is turned off or the DESS key is removed
  • The power interface has a fuse protected voltmeter included and an extra fuse to protect from polarity inversion of the power supply cable
  • It's necessary for BRP vehicles without a battery (electric starter).
[Image: BRP-Power.jpg]
BRP SeaDoo/Skidoo DESS Interface 4-Tec - $335
  • Designed for add/erase DESS keys for 4-TEC models of SeaDoo and Skidoo vehicles.
  • This device is connected between the MPI Interface and the diagnostic cable and is used only for procedures with DESS keys.
[Image: BRP-DESS.jpg]
BUDS Megatech License - $99
B.U.D.S. (BRP Utility and Diagnostic Software) is a comprehensive diagnostic software.
Megatech is a BUDS software developer license. This license is for advanced configuration of electronic modules, as well as for clearing history and information about modules, recovering from update failures.
It applies to all BRP 1996-2016 vehicles: SeaDoo, Can-Am, Skidoo.
[Image: BRP-BUDS.jpg]
License Mechatronic Expert (cover all BRP: SeaDoo, CanAm, Skidoo, Roadster, ATV, SSV)
  • Mechatronic Expert 7 days - $65
  • Mechatronic Expert 1 month - $110
  • Mechatronic Expert 3 months - $170
  • Mechatronic Expert 6 months - $299
  • Mechatronic Expert 1 year - $455
  • Mechatronic Expert 2 years - $615
  • Mechatronic Expert 5 years - $945
  • Mechatronic Expert 10 years - $1499
In addition to the main features of the Dealers license, the Mechatronic license allows:
  • Change VIN and Model's numbers (useful after replacing the ECU)
  • View stories in hours, not percentages
  • Enable/disable DESS (start the car with any button (except Roadster Spyder)
  • Change the type of DESS key in two clicks (regular, training, rent)
  • Clear ECM history (useful after ECU replacement)
  • Change the total number of engine hours (SeaDoo)
  • View additional information blocks
  • Edit injector ratio for E-TEC Skidoo
  • Enable / disable vehicle options / modules / sensors
  • Increase Spark power from 60 hp. up to 90 hp.
[Image: BRP-Mechatronic-Expert.jpg]
License All Dealers Technician (cover all BRP: SeaDoo, CanAm, Skidoo, Roadster, ATV, SSV)
  • All Dealers Technician 1 year - $270
  • All Dealers Technician 2 years - $390
  • All Dealers Technician 5 years - $615
  • All Dealers Technician 10 years - $999
[Image: BRP-Dealers.jpg]
License Dealer Technician (cover 1 type of vehicle)
  • Dealer Technician SeaDoo or SkiDoo or ATV or SSV or Spyder 1 year - $115
  • Dealer Technician SeaDoo or SkiDoo or ATV or SSV or Spyder 2 years - $189
  • Dealer Technician SeaDoo or SkiDoo or ATV or SSV or Spyder 5 years - $425
  • Dealer Technician SeaDoo or SkiDoo or ATV or SSV or Spyder 10 years - $699
Need it? Write to me to discuss the details.
3 Guest(s)
