App Cloner Review
In this guide, I'm going to show you how you can create a bootable Windows USB with Win32 Disk Imager. If you have ever been asked or have needed to install an operating system on another computer, you may have found it necessary to create a bootable USB to easily install it anywhere. And of course, although doing so is relatively simple, you may not have the knowledge to do it.
That is why today we will explain how to carry out this process using Disk Imager, and we will try to do it simply so that anyone can do it without problems. We are going to do it on the one hand with Windows 10, which has the easiest method, and on the other with Ubuntu because it is one of the GNU / Linux distributions of reference.
First of all download and install Win 32 Disk Imager on your PC. When you run the application for the first time, you will see that it presents you with two options to proceed. The preselected one will be that of Distribution, which will allow you to choose a distro from the list. First, you will have to choose the one you want to use from the distribution drop-down and then open the version next to it to choose the one you want.
Download App Cloner:
https://win32diskimager.download
https://wiki.ubuntu.com/Win32DiskImager
The free version of App Cloner is perhaps a bit limited. This allows you to clone applications, so that you can log in to multiple accounts, for example. Handy, because that way you don't have to log in and out of a certain application such as Facebook. Please note that this is not possible with every application. In the Google Play Store are the applications that you can clone and which cannot.
The paid version costs around four euros and contains many options to customize your applications. In the paid version you can install an application on your SD card, rotate icons, prevent a certain application from using your data bundle and use multi-window. The latter option is only available for Samsung devices. You can also use the paid version to remove widgets from applications and not show applications in recent applications.
[Image: App-576x1024.png]
  App Cloner Review belangerr 0 199 11-02-2019, 08:17 PM
Last Post: belangerr
