Someone bought JPRO professional heavy truck scanner - Printable Version
+-- Forum: FREE Zone (https://www.auto-epc.org/forumdisplay.php?fid=155)
+--- Forum: FREE Zone Requests & Supports (https://www.auto-epc.org/forumdisplay.php?fid=159)
+--- Thread: Someone bought JPRO professional heavy truck scanner (/showthread.php?tid=15607)
Someone bought JPRO professional heavy truck scanner - Martin56 - 02-01-2023
I checked his profile and it shows
JPRO Professional heavy duty truck scan tool is an easy to use diagnostic tool that can help you establish the possible problem. You will be surprised how this scan tool goes more in-depth and takes diagnosis to the next level.
It is a simple yet most comprehensive and powerful diagnostic tool that is compatible with all models. Besides, JPRO Professional heavy duty truck scan tool provides complete and real-time diagnostic services. It is also uniquely designed to provide a repair solution for the diagnosed problem, and better yet, is equipped with bi-directional functionality.
Friends, what do you think if you can buy it
RE: Someone bought JPRO professional heavy truck scanner - Daysi - 02-01-2023
(02-01-2023, 12:06 AM)Martin56 Wrote: I checked his profile and it shows
Can JPRO heavy duty trucks Diagnostics clear Fault Codes? Yes, JPRO heavy duty trucks Diagnostics has the ability to clear both active and inactive fault codes. JPRO Diagnostics can also clear a single selected fault code.
Does JPRO Professional Diagnostic Tool work on a PC running Microsoft Windows Vista? JPRO Professional Diagnostic Tool support Windows 7 Ultimate 32bit&64bit,Windows 7 Professional 32bit&64bit
